ROM Update :: Phiên bản nâng cấp đầy đủ cho hx4700
HP vừa công bố bản ROM Update cho dòng sản phẩm iPAQ hx4700. Phiên bản 1.10 này có nhiều nâng cấp như sau:
Provides an improved Microsoft Pocket Internet Explorer.
• Provides an improved Microsoft Windows Media Player.
• Enables more than one Settings application to be active at the same time.
• Adds new data connectivity icon to the Title bar.
• Improves ServerSync application stability.
• Enables dialing of a number that starts with a pound sign (#).
• Enhances localization, including:
• Traditional Chinese: Improves Wi-Fi settings “Zero Config” dialog box.
• Japan: Improves Wi-Fi settings.
• Korean: Updates the Lunar calendar.
• Enables the pound sign (#) and asterisk () to be used in the Contacts application search function.
• Fixes issues with wireless connectivity.
• Fixes issue with execution of .NET framework.
• Fixes issue with very high-volume audio signal from third-party applications that could result in potential speaker damage.
• Fixes issue where the microphone automatic gain control (AGC) setting was not saved after a power cycle.
• Fixes issue where the user interface for the handheld would indicate that the user was connected to a network that was not present.
• Fixes issue where protected extensible authentication protocol (PEAP) authentication would fail with no indication that the user’s password had expired.
• Fixes issue where Pocket Internet Explorer would stall and fail to load a page if the HTTP post was larger than 16K.
• Fixes issue where WiFi connection status was incorrectly indicated for some conditions.
• Fixes issue with an active modem connection where the handheld was unable to re-establish a connection after the USB cable was unplugged.
• Fixes issue that occurred when using WPA-PSK authentication where the handheld failed to authenticate to a second access point (AP) with the same SSID and key.
• Fixes issue where the client device packets did not properly route to the target LAN when a point-to-point protocol (PPP) connection was made.
• Fixes issue where an exception was generated When disconnecting a XXXXXX line Internet protocol (SLIP) server session.
• Fixes issue where the wrong domain name server (DNS) address was passed to the server when a secondary IP address was assigned.
• Fixes issue where the wrong WEP key was used when switching between configured, preferred, WEP-enabled Wi-Fi connections.
• Fixes issue with cached pages where a back/forward navigation would not be sent to the Internet.
• Fixes issue with URLs that contain semicolons so that they are no longer truncated when sending the GET request over the Wireless Session Protocol.
• Fixes the following localization issues: Korean: Fixes issue with contact picker where it did not match Jungseong because asterisk (
) and pound sign (#) key presses were ignored; fixes issue with contact names that were displayed with no comma or space between the Last and First name; fixes issue with the Notification dialog so it is no longer clipped in the Sounds and Notifications Control panel. Romanian: Corrects Daylight Savings Time.
Đáng tiếc phiên bản ROM mới này không có WM10.
Link: http://h18007.www1.hp.com/support/files/HandheldiPAQ/us/download/22658.html
Chúc vui !!!
Oh my god ! Oh my god ! Oh my god ! Oh my god ! !!! Ơn trời… đa tạ… chờ ngày này lâu lắm rồiiiiiiiiiiii
Live show cho bà con coi luôn nha:
10h45PM : Cài đặt file Setup SP29841.exe
10h47PM: tiến hành Up ROM. Yêu cầu Device đã được sync với PC wa Active Sync. Ipaq sẽ tự tắt tất cả chương trình (ngay cả OS) để up ROm. LÚC NÀY TUYỆT ĐỐI KHÔNG ĐƯỢC THÁO CABLE RA KHỎI DEVICE !
Wá trình cài đặt như sau :
http://i4.photobucket.com/albums/y134/bun2it/uP.jpg
11h07PM : kết thúc wá trình Up Rom. Thành công tốt đẹp ! Sẽ review ngay khi có điều kiện vì đang vọc hehehe…
sau khi test thi co thay doi nhu sau:
  • Song wifi cuc manh tang khoang 50% ve power of signal
  • WINDOW MEDIA PLAYER 10
  • Bluetooth nhanh hon binh thuong
con tiep…
P/s : em moi up rom chua kip cai bo go … tha cho em nhe
Sao thấy mấy trang nước ngoài và bác oh_my_god nói là không có WINDOW MEDIA PLAYER 10 :-?
Bun2it ơi mấy cái phần mềm thứ 3 (Pocket Information 5.x, DockWare, Rhinocode TodayPanel …) như có còn trong ROM của bản 1.10 không? mình ghét mấy thằng này, không có thì tốt quá.
Em mới download bản Update lúc 6h30 sáng, thì 6h40 sáng phải đi làm rồi, nên cũng chưa update lên không rõ lắm, bác bun2it chọc từ trưa đến giờ chắc là thêm được nhiều thông tin rồi, up lên cho anh em biết với.
Thank for ALLLLLLLLLLLLLLL
tất cả đều còn nguyên, được nâng đời nữa là khác, Clearvue Pdf, Wm10, wifi…
Hix… đến hôm nay em mới nếm mùi đau khổ của các bác xài Wm10… chia sẻ chia sẻ…
Kinh nghiệm trứoc khi up rom : nhớ backup tòan bộ PIM. Ko là mất hết, ngay cả data wan trọng có để trg ipaq store cũng phải chuyển đi.
@wildcat: em ở US mà anh :smiley: bên em đg là 11h30 đêm rồi !
upgrade
có WM10 đấy bác, mình cũng vừa up xong, thanks bác oh_my_god & bun2it nhieu lam.
như bác bun2it nói, các bác copy tất cả data quạn trọng trong ipaq store, và backup tất cả , sau khi up xong các bác chạy restore lại để đỡ mất thời gian cài lại các soft.
… nhưng khi đó thì Wm10 sẽ mất skin luôn hehehe… phải HR lại thôi… hix hix muốn downgrade cái WM này wá !
Mà cái bệnh ko lưu cookies vẫn còn ? Với lại ko cho chép font tahoma vào Rom nữa chứ
Không có copy Tahoma vào ROM là sao, vậy thì mấy phần mềm tiếng Việt như Kinkin có hiển thị tiếng Việt đúng không?
Bác cho một bài dài dài một chút.
bản 1.0 cũng vậy mà đâu có copy font vào rom đâu? bác cài ppc -vn system VN unicode font, là đọc tốt tất cả mà.
Em Uprom xong hết rồi các bác ơi, có một số vẫn đề như sau.
  1. Về giao diện em thấy kô khác cái bản cũ gì hết.
  2. Có có khác thì cũng chỉ là có MP10 đó các bác àh.
  3. Nhưng khi restore thì MP10 bị mất Skin thật, bác nào có võ lấy lai skin được kô?
  4. Một số file phim của em kô chạy được trong BetaPlayer 0.95 nữa buồn như con chuồn chuồn …
̀5. Khới động chậm hơn bản cũ tương đối.
Tạm vậy nhé vì em mới Uprom lên chưa tim hiểu kỹ. Có gì hay các bác review tiếp nhé.
@wildcat: ko cho phép mình copy font tahoma nhưng những font khác thì ok ! Check web và gõ tv vẫn ok, chỉ có giao diện setting cho VNkb thì ko hiện font được vì ko có tahoma.
phần HP protectool phong phú hơn bản trước, nó có chế độ bảo mật rất cao, ngoài ra còn có encryp data trước khi tắt máy. Nhưng cái nầy dùng phiền hà và bất tiện lắm. còn WM10 đối với máy mình khi restore vẫn còn giử được skin của nó (không hiểu tại sao cả)
Túm lại là phiên bản Rom mới này có WM10 không vậy các bác ? Nếu có nhờ các bác capture screen luôn rồi post lên đây nhé.
Trùi bác kô đọc kỹ gì cả, mọi người vẫn đang ban đến cái MP10 đó thôi. Bản ROM mới mà kô có MP10 thi còn nói chuyện gì. Mà tôi dùng MP10 trên HP4700 thấy binh thương đó có gì khó đâu mà mọi người kêu trới vậy. Y trang như ở PC thôi.
@ All: Em khoái nhất là nó tích hợp .NET framework SP3 và lỗi âm thanh lớn khi sử dụng phần mềm thứ 3 lên không phải cài lại mỗi lần HS nữa (tiết kiệm được 1 ít RAM ;))
Mở trang Web lớn không còn báo lỗi nữa (lớn hơn 16K), nhưng thỉnh thoảng vẫn bị TREO, không rõ xung đột với thằng nào (em chưa có thời gian cài từng thằng 1 để kiểm tra).
Còn nhiều cái khác nữa nhưng chủ yếu phần lớn là sửa lỗi thôi.
@ bun2it: Em không hiểu bác nói copy phông vào ROM là sao??? đâu có copy cái gì vào ROM được (trừ khi có phần mềm Unlock ROM thôi). Còn như copy vào thư mục Windows thì ngon lành mà, hôm qua em đã up ROM xong, copy nguyên bộ phông Tahoma của Windows Media Center 2004 vào thư mục windows được mà.
Đúng như bác nói sóng FiWi khoẻ hơn thật sự em sẽ kiểm nghiệm rồi.
@ truongbx: đúng là lỗi một số file khi sử dụng BetaPlayer 0.95 (cái này mấy trang nước ngoài cũng bàn tán nhiều)
@ oh_my_god: Chắc chắn là có WM10, mà các bác nói sao ấy, em thấy dùng thằng mới này đã hơn âm thanh ra hay hơn (nghe bằng tai nghe, file MP3 được copy từ đĩa nhạc xịn… mới nhận biết được cái hay)
hix hix nhưng bệnh cũ là ko lưu cookies vẫn còn ! Ko save được font Tahoma vào Window ko hiểu tại sao ? và Restore thì vẫn mất skin ? thế là thế nào nhỉ :-?
Cái vụ cookies thì em không rõ vì chưa có tìm hiểu, còn như không copy phông tahoma vào Window được là vì có lẽ bác dùng thằng Explore gốc của PPC thì phải, bác dùng thằng Resco Explore đi (copy phông tahoma vào thẻ, rồi dùng Resco Explore copy to… vào Window
Hình minh hoạ cho bác Oh_My_God yên tâm đây
http://img.photobucket.com/albums/v655/wildcathcm/WM10.jpg
sau khi HR và restore lại 1 lần nữa thì skin đã hiện ra ko đen thui nữa, khó hiểu thật ! Font chep từ PC wa sync được rồi ! Chỉ còn vụ cookies thôi !
