Review nội thất và chức năng wifi công nghiệp: Aerohive AP370
THông tin về bộ phát wifi công nghiệp
Hãng : aerohive USA , giờ nó đã thuộc về công ty mẹ Extreme Network, 1 thế lực nổi lên thâu tóm rất nhiều công ty trong lĩnh vực mạng
Model review hôm nay là AP370
Thông số cấu hình :
[TABLE]
[TR]
[TH]Aerohive AP370 Specifications[/TH]
[TH][/TH]
[/TR]
[TR]
[TD]Radio Specifications—802.11a[/TD]
[TD]
  • 5.150–5.950 GHz Operating Frequency
  • Orthogonal Frequency Division Multiplexing (OFDM) Modulation
  • Rates (Mbps): 54, 48, 36, 24, 18, 12, 9, 6 w/ auto fallback
[/TD]
[/TR]
[TR]
[TD]Radio Specifications—802.11b[/TD]
[TD]
  • 2.4–2.5GHz Operating Frequency
  • Direct-Sequence Spread-Spectrum (DSSS) Modulation
  • Rates (Mbps): 11, 5.5, 2, 1 w/auto fallback
[/TD]
[/TR]
[TR]
[TD]Radio Specifications—802.11g[/TD]
[TD]
  • 2.4–2.5 GHz Operating Frequency
  • 20 dBm (100 mW) Transmit Power
[/TD]
[/TR]
[TR]
[TD]Radio Specifications—802.11n[/TD]
[TD]
  • 2.4–2.5 GHz & 5.150–5.950 GHz Operating Frequency
  • 802.11n Modulation
  • Rates (Mbps): MCS0–MCS23 (6.5Mbps - 450Mbps)
  • 3x3:3 Stream Multiple-In, Multiple-Out (MIMO) Radio
  • HT20 High-Throughput (HT) Support (for both 2.4 GHz and 5 GHz)
  • A-MPDU and A-MSDU Frame Aggregation
[/TD]
[/TR]
[TR]
[TD]Radio Specifications—802.11ac[/TD]
[TD]
  • 802.11ac Modulation (256-QAM)
  • Rates (Mbps): MCS0–MCS9 (6.5Mbps - 1300Mbps), NSS = 1-3.
  • VHT20/VHT40/VHT80 support
[/TD]
[/TR]
[TR]
[TD]Mounting[/TD]
[TD]
  • Desktop
  • Wall Mount included as part of AP
  • Built-in slot for Kensington type locks
  • Ceiling and Wall Mount locking accessory included with AP
  • Ceiling Tile flush 15/16” included as part of AP
  • Ceiling Tile Recessed 15/16”, 3/8”, 9/16” sold as an accessory
  • Ceiling Tile flush 3/8”, 9/16” sold as an accessory
  • Suspend Mount sold as an accessory
  • Plenum Mount sold as an accessory
[/TD]
[/TR]
[TR]
[TD]Antennas[/TD]
[TD]
  • 3x Integrated single band, 2.4-2.5 GHz Omni-directional antennas, 6.0 dBi peak gain
  • 3x Integrated single band, 5.1-5.8 GHz Omni-directional antennas, 6.0 dBi peak gain
[/TD]
[/TR]
[TR]
[TD]Interfaces[/TD]
[TD]
  • 2x autosensing 10/100/1000 Base-T Ethernet Ports
  • Dual Ethernet ports with backhaul capabilities
  • Link Aggregation supported via Ether channel (link aggregation)
  • 1x Serial RJ45 port (bits per second: 9600, data bits: 8, parity: none, stop bits: 1, flow control: none)
  • USB 2.0 port (3G/4G WAN connection – Operating as a BR)
  • 1x Reset Pinhole
[/TD]
[/TR]
[TR]
[TD]Physical[/TD]
[TD]
  • WxHxD: 7.68in.x1.57in.(2.2in at peak) x 7.68in. (19.5cm x 4cm (5.5cm at peak) x 19.5cm)
  • Weight: 1.5 lbs (0.68 kg)
[/TD]
[/TR]
[TR]
[TD]Environmental[/TD]
[TD]Operating: 0 to +40°C, Storage: -20 to +70°C Humidity: 95%[/TD]
[/TR]
[TR]
[TD]Environmental Compliance[/TD]
[TD]UL 2043[/TD]
[/TR]
[TR]
[TD]Power Options (sold separately)[/TD]
[TD]
  • 802.3af and/or 802.3at Power over Ethernet PoE Injector
  • 12v DC external power adapter
  • Aerohive switch products
[/TD]
[/TR]
[TR]
[TD]Power Specification[/TD]
[TD]
  • AC/DC power adapter: – Input: 100–240 VAC – Output: 12v/2.0A
  • PoE nominal input voltages: 48V, 0.35A, (802.3af) – 48V, 0.625A (802.3at)
  • RJ-45 power input pins: Wires 4,5,7,8 or 1,2,3,6
  • 802.3af compliant with Cat-5 cable or higher
[/TD]
[/TR]
[/TABLE]
data sheet của AP370
https://www.aerohiveworks.com/datasheets/Aerohive-Datasheet-AP370_new.pdf
Thông tin thêm về phần cứng mà hãng không đưa ra
CPU : dual core 800Mhz
RAM : 512MB
2 cổng lan 1Gb, có thể cấu hình đơn lẻ, hoặc 1 lan in, 1 lan out,
dùng nguồn adapter 12V hoặc POE chuẩn at qua cổng eth0
khả năng gánh tải : 100user
chức năng khác : Mesh sóng wifi giữa các bộ phát wifi của hãng với nhau , vừa mesh không dây vừa mesh dây lan.
HÌnh ảnh :
Ngoại hình nắp cabo ( nắp này bằng nhựa composite rất cứng và bền, vị trí này để các anten bên trong phát sóng )
dãy đèn led ở giữa sáng đẹp ( khởi động đèn đỏ, khi khởi động và dùng sẽ có màu trắng )
[ATTACH type=“full”]1042174[/ATTACH]
bên hồng : thiết kế kiểu viên kim cương rất đẹp mắt.
[ATTACH type=“full”]1042175[/ATTACH]
đít thiết bị được lại bằng nhựa cứng giống nắp, và các thông số
[ATTACH type=“full”]1042176[/ATTACH]
Bên trong đít nhựa này là khung thép tản nhiệt của các cpu và card wifi
[ATTACH type=“full”]1042177[/ATTACH]
Tổng quan về mainboard thành phần cốt loại của thiết bị
dưới cục nhôm đen lớn là CPU dual core 800Mhz cùng với ram 512MB
cục nhôm đen nhỏ là chipset ethernet 1Gb
cấp nguồn poe
[ATTACH type=“full”]1042178[/ATTACH]
[ATTACH type=“full”]1042179[/ATTACH]
cổng usb và nút reset :
[ATTACH type=“full”]1042180[/ATTACH]
2 modun phát sóng wifi : những thiết bị wifi công nghiệp thường có 2 modun riêng, 2 radio , 1 cái raddio 2,4Ghz và 1 cái radio 5Ghz : phát sóng trên 2 băng tầng
Modun 5Ghz
[ATTACH type=“full”]1042181[/ATTACH]
modun 2.4Ghz
[ATTACH type=“full”]1042182[/ATTACH]
mặt dưới của bo mạch
[ATTACH type=“full”]1042183[/ATTACH]
thành phần rất quan trọng trong cục phátwifi không thể thiếuđó là bộ anten
ap 370 có tổng cộng 6 anten 6dbi
phát sóng rất tốt.
[ATTACH type=“full”]1042184[/ATTACH]
[ATTACH type=“full”]1042185[/ATTACH]
[ATTACH type=“full”]1042186[/ATTACH]
[ATTACH type=“full”]1042187[/ATTACH]
đã xong về phần cứng.
Vài sau em sẽ review về phần mềm, quản lý của aerohive trên cloud Extreme miễn phí của hãng
Quản lý tất tần tật các chức năng dựa trên cloud.
Mod ơi, em đâu có mua bán đâu, sao lại bị move vào mục mua bán vậy ?
em đang làm bài hướng dẫn sử dụng nữa mà.
Em này so với em Aruba 225 thì có hơn không bác NeO?
nó hơn aruba225 ở khoản quản lý qua cloud và tầm sóng rộng hơn do anten lớn hơn thôi anh
Like bài của bác, em đang dùng 2 em 220 ở nhà
Sent from my SM-G885F using Tapatalk
em cũng không hiểu sao mod lại move nó qua mục mua bán, làm em chuẩn bị 1 bài viết hướng dẫn tạo tài khoản và cấu hình để đạt hiểu quả cao nhất với cloud extreme .
làm cụt hứng viết bài ghê gớm luôn đó ạ
@syhuy1977 @Lam Sơn : Nhờ Smod xem dùm em move bài về đúng box được không ạ.
XIn cảm ơn Mod đã move topic về đúng vị trị
Em xin hướng dẫn các bước tạo tài khoản extreme cloud miễn phí và dùng vĩnh viễn.
B1 : truy cập vào địa chỉ : https://extremecloudiq.com/login
B2 : bấm vào chữ : Register here để bắt đầu tạo tài khoản mới.
B3 : điền các thông tin của mình, click chọn Unlimi và bấm Reg[ATTACH type=“full”]1043829[/ATTACH]
B4 : kiểm tra hộp mail. sẽ nhận được 1 mail đăng ký tài khoản.
click vào link ( set Password) sẽ dẫn tới 1 trang đăng ký mật khẩu cho tài khoản cloud của bạn
B5 : nhập password của bạn vào
[ATTACH type=“full”]1043830[/ATTACH]
B6 :
lựa chọn dòng cuối : I’ll start with ExtremeCloud IQ Connect. sẽ được dùng cloud extreme miễn phí và trọn đời.
sau đó bấm Get Started! : để bắt đầu sử dụng cloud
[ATTACH type=“full”]1043831[/ATTACH]
Đã xong quá trình tạo 1 tài khoản cloud miễn phí và vĩnh viễn, sẽ có nhiều anh em chỗ bước 6 này chọn 30 ngày thì sẽ bị giới hạn rất nhiều chức năng của sp và chỉ dùng được 30 ngày sẽ khóa hết và bắt buộc phải mua tài khoản,. giá tài khoản prenium 1 năm là 100$ rất cao,. dùng miễn phí cho tiết kiệm và đầy đủ chức năng.
Hướng dẫn cấu hình, cài đặt wifi của aerohive trên cloud
Sau khi log in tài khoản vào cloud.
bỏ qua các giai đoạn quản cáo và wizard của hãng.
B1 : Vào common objects :
[ATTACH type=“full”]1046332[/ATTACH]
B2 : chuyển tới Policy- radio Profiles
Click chọn : radio_ng_ac0 _ bấm Icon :Clone để nhân bản profile này ra 1 cái khác, có thể đặc tên cho dễ nhớ
trong bài viết này hướng dẫn trên thiết bị là wifi chuẩn AC, nếu chuẩn AX hay N thì các bạn chọn profile radio tương ứng để clone và edit.
[ATTACH type=“full”]1046333[/ATTACH]
B3 : đặc tên profile radio và edit profile này để cho wifi đạt tốc độ max trên băng tầng 5Ghz
chọn độ rộng là 80Mhz ( trên chuẩn AC, 40Mhz trên chuẩn N) để đạt tốc độ cao nhất và tránh nhiễu tốt nhất.
các hạng mục lựa chọn ở dưới như công suất phát, rssi, kênh sóng… các bạn có thể tùy chọn hoặc để mặc định, nó sẽ tự chọn cái tối ưu nhất.
[ATTACH type=“full”]1046334[/ATTACH]
Đã xong phần edit radio profile, đây là phần cơ bản quan trọng nhất để cho băng thông wifi đạt max tốc độ,
chúng ta chỉ cần edit trên sóng 5Ghz thôi, còn sóng 2,4Ghz để mặc định, hãng không cho edit độ rộng, mà chỉ cho edit kênh sóng, khả năng chịu tải, rssi, công suất phát, nên cứ để mặc định dùng radio profile gốc cũng được không sao cả.
Tiếp theo là : Network Policies : phần này là cốt lõi cả cài đặt wifi, tên wifi, password, cap quản cáo, cho cổng eth1 chức năng access hoặc… và cho ép usb dùng hay không dùng.
B4 : Bấm vào CONFIGURE - Network Policies - Add Network Policy
[ATTACH type=“full”]1046335[/ATTACH]
B5 : đặt tên Policy theo ý mình ( 1 tài khoản miễn phí sẽ tạo được 3 policy này , mỗi policy có thể add nhiều thiết bị AP khác nhau vào chung 1 policy để có thể mesh quản lý tập trung với nhau)
và bấm save>
[ATTACH type=“full”]1046336[/ATTACH]
B6: Wireless Networks :
đây là mục mình tạo những tên SSID wifi theo mong muốn và theo băng tầng hoặc là combo, ở mục này cho phép chọn mạng guest hay standard .
[ATTACH type=“full”]1046337[/ATTACH]
B7 : tạo tên wiif, ssid
có thể tạo tối đa 16 tên wifi
và có thể gán tên wifi cho từng băng tầng 2,4 hoặc 5G hoặc combo tùy thích.
[ATTACH type=“full” alt=“B7.jpg”]1046339[/ATTACH]
Save lại và qua tiếp theo.
B8 : Đây là bước add model wifi vào, bước này quyết định việc dùng modun wifi 2,4 hay 5G dùng radio mà mình đã tạo ở B1.
nếu bạn có nhiều model aerohive khác nhau, và muốn dùng chung policy với nhau thì add lần lược model vào, và chúng sẽ dùng chung và có thể mesh được với nhau .
[ATTACH type=“full” alt=“B8.1.jpg”]1046340[/ATTACH]
[ATTACH type=“full” alt=“B8.2.jpg”]1046341[/ATTACH]
Và bấm : SAVE TEMPLATE : ở góc phải dưới.
các bước tiếp theo là next và exit.
Trong trường hợp : dùng 2 hay nhiều model aerohive với nhau, thì ở B8 này các bạn tiếp tục add các AP templates vào với nhau, để chúng có thể dùng chung polici và mesh được với nhau.
Xong, vậy là đã tạo thành công 1 Polici.
Giờ đến lược add seri vào cloud và chọn policy và ngồi đợi cho upload xuống và tận hưởng thành quả.
B9 : Add seri
[ATTACH type=“full” alt=“B9.jpg”]1046342[/ATTACH]
[ATTACH type=“full” alt=“B9.1.jpg”]1046343[/ATTACH]
chọn quick add devices
[ATTACH type=“full”]1046344[/ATTACH]
Giờ thì ngồi đợi cho nó upload xuống khi nào báo xanh thì sẽ bắt đầu dùng được rồi.
Khi thiết bị đã được upload cấu hình xuống, đèn trên ap sẽ chuyển sang màu trắng, và sẽ lên sóng wifi dùng
trong trường hợp có nhiều bộ phát và muốn quản lý dễ thì chỉ việc click vào tên từng cái và edit tên theo ý muốn và sava lại.
[ATTACH type=“full”]1046346[/ATTACH]
Bác chủ tư vấn giúp em với. Em ở chung cư, đang phát wifi qua cục modem của nhà mạng, sóng wifi băng 5Ghz trong phòng ngủ rất yếu. Em muốn dùng 1 con phát wifi riêng để cải thiện phạm vi phủ sóng. Bác có con nào ngon-bổ-rẻ, dễ cấu hình không ạ.
Sóng 5Ghz tốc độ cao, nhưng khả năng phát xa và xuyên tường kém.
Để dùng tring nhà chung cư thì có thể dùng 2 bộ phát để mesh với nhau mà không cần đi dây mạng, còn nếu có dây mạng ở các phòng thì gắn lan mesh đều được ạ.
Bác có con nào có chức năng này không ạ
Những bộ phát công nghiệp như extreme, aruba, đều có.
Nhưng nếu bác muốn đơn giản kiểu dễ hiểu dễ làm thì inbox em :smiley: zalo viber 0982060613
Em còn nhiều thứ nữa lắm
em 2 con này, sao thi thoảng thấy nó bị tắt đèn với mạng cảm giác chậm ấy bác?
chế độ dim light của aerohive thôi ạ. nó không sáng đèn liên tục đâu.
