Your most important information at a glance. myCodes Pro manages your important data categorized and secure. Manage as many safes as you need for your private or business data. Decide for your own if you need a secured or open safe. Mark your most important information as value or password. They will be displayed in the quick view to each record.
Here are some key features of “myCodes Pro”:
· As many safes as needed - encrypted safes for data that needs to be protected against unauthorized access (128bit RSA encryption), open safes for storing unsensitive data
· Categories sort your entries clearly arranged
· Cards (templates) offer the possibility to define the input screens to your needs
· For each record you have up to twenty input fields, defined by the assigned card
· Cards offer individual icons and different field types (standard, multiline, value, internet-URL, password)
· "Safe Mode": Program settings are secured by password, 10 minute lock out after three times entering a worng password
· Safe gets locked after standby of your PocketPC or after reaching a specified time period
· Data overview: Quick view - shows the values and passwords, detail view - shows all available data in fullscreen mode and offers the possibility to follow internet links (when internet connection is available)
· Clipboard support when entering or viewing data
· Data entrance - available fields are dependend on the assigned card
· File area: Move important documents and files into your safe - Voice recorder - Handwritten notes or drawings
· Password generator
· Import of myCodes lite data
· Export to XML or as a text file
· Setup assistant: Generation of sample cards and categories
· Dynamic Help
· Individual color definitions
Limitations:
· The version contains full functionality. The only restriction is, that you can manage only two safes and three records per safe.
What’s new in this release:
· Better XML import and export format
· Better support for landscape and square screens
· More usable keyboard behavior
Requirements:
· PocketPC 2002, WindowsMobile 2003 (SE), Windows Mobile 5 ARM or XScale CPU
Một vài hình ảnh:
http://img387.imageshack.us/img387/8678/pccapture7vp7.pnghttp://img452.imageshack.us/img452/5400/pccapture9al3.png http://img387.imageshack.us/img387/3128/pccapture12qp5.png
Link để tải về,bộ cài có 3 phần,cài lần lượt lên Memory Card hết nhẻ:
http://www.4shared.com/file/14019625/6fa62a7d/myCodes_Pro.html
