Phần mềm jailbreak iphone: Jailbroken Quick Tool 1.5.1
[INDENT]Jailbroken Quick Tool 1.5.1 New Updates hello…
new version available Jailbroken Quick Tool 1.5.1
whats new?
This version is compatible to all iTunes version,it will automatically update your .dll files.
no wifi method added
UltraSn0w 1.2.3 is added compatible to iOS 4.3.3
with this version of 1.5.1 i put some functions that everytime that ultrasn0w have an updates,button for ultrasn0w will automatically update.http://forum.gsmhosting.com/ubb/smile.gif
i also add ultrasn0w fixer it will enable if new version from author is out again.
also add some stuff…
Locktopus = Password-protect individual apps DIRECTLY from SpringBoard! No need to open another app and respring.
AndroidLock = An Android-like lockscreen where you have to draw the correct pattern to unlock.
Graviboard = Adds gravity to SpringBoard! iOS4
Haptic = Haptic / Vibration Feedback everytime you push some button to your iDevice
i put again Celeste with complete dependecies
Celeste = Bluetooth file sharing for iOS4!
screenshot here.
http://www.mediafire.com/imgbnc.php/d7e050b5ec64c0b89bd32b321c4612199af4287bb57bb58b4425ede1210effd76g.jpg
Download:
http://www.mediafire.com/?j4vzzfcuu1i1hvf
Password để giải nén: 5ncnow.com
[/INDENT]
mình tải về rồi và cài ra nhưng khi sử dụng thì nó báo lỗi connect tới server là sao bác nhỉ! bác cho bài hướng dẫn cụ thể đi!
