New: WisBar Advance Desktop 1.0 build 4 (1.0.0.4) 06/01/2006 - Đợi mãi giờ mới ra
Hôm nay ngày 6/1/2006 theo giờ Việt Nam và là ngày 5/1/2006 theo giờ nước bác Chris_McKay, bác Chris_McKay đã cho ra lò bản WisBar Advance Desktop 1.0 build 4 với nhiều thứ mới.
http://laptop4rum.org/wildcat/upload/SoftPDA/WisBar_AD_10build4/WAD1042.jpg
http://laptop4rum.org/wildcat/upload/SoftPDA/WisBar_AD_10build4/WAD1041.jpg
  • Enhancements
  • Increased the loading speed when switching between portrait and landscape modes.
  • Added the ability to determine what pages are selected when using the “Next Page” and “Previous Page” button actions on a button-by-button basis.
  • Added an analog clock object. (hay nhỉ)
  • The fullscreen option is now specific to each virtual page.
Bugs Fixed
  • Tapping in an area where a pinned object that has been removed from the page would be now executes correctly.
  • Fixed a bug where objects may not have their fonts set correctly.
  • Pinned Today plugins that have been removed from a page now disappear correctly.
  • Fixed a few issues with the fullscreen mode.
  • Fixed a bug where new text objects didn’t display immediately.
  • Changed the icon for the Theme Manager.
  • Fixed a bug where the user could not tap on the Today screen when toggling the WisBar Desktop window off.
  • Corrected the issue where the program would lock up the device on exit.
  • When switching pages, the Today plugins are sent a message that “should” force them to redownload the background image. However, this is dependant upon how the plugin was developed.
[size=2]Downloads[/size]
                   [size=2]**New users**: The program will operate as a fully functional 7-day trial.  When the trial is complete,                       you will need to either uninstall the software or purchase it.
Registered users: Please download one of the files below. The program will work indefinitely once you have entered your registration information. It is safe to install this program on top of previously installed versions.
[/size][size=2]Desktop Installer[/size]
[size=2]click here to download](http://www.lakeridgesoftware.com/downloads/wisbardesktop.exe)
PPC2002, WM2003/SE, WM5.0 devices[/size]
[size=2]
[/size]
[size=2]CAB Installers[/size]
[size=2]click here to download](http://www.lakeridgesoftware.com/downloads/wisbardesktop.armv4i.cab)
WM5.0 devices[/size] [size=2]
[/size] [size=2]click here to download](http://www.lakeridgesoftware.com/downloads/wisbardesktop.armv4.cab)
WM2003, WM2003SE devices[/size] [size=2]
[/size] [size=2]click here to download](http://www.lakeridgesoftware.com/downloads/wisbardesktop.arm.cab)
PocketPC 2002 devices[/size]
WisBar Advance Desktop 1.0 build 5
  • Enhancements
  • If WisBar Advance is not installed, the installation of WAD will fail.
  • Text objects can now display information about pending notifications.
  • Text objects can now display the current phone connection status.
  • Text objects can now display the current signal strength (in number of bars).
  • Added the ability to change the width of the hour and minute hands on the analog clock.
  • Added the ability to manually change the radius of an analog clock.
  • Buttons can now execute 2 actions simultaneously.
Bugs Fixed
  • Fixed a bug where the WisBar settings program would close the desktop.
  • Fixed a bug where the wallpaper was not reloaded when switching between landscape and portrait orientations.
  • The analog clock is now available to be placed on a dock.
  • Fixed a bug where text objects did not resize or update properly.
  • Fixed a bug where the default font shadow colors was not being applied properly.
  • Reduced the slowdown caused by viewing the appointments and tasks text objects.
PPC2002, WM2003/SE, WM5.0 devices[/size] [size=2]
CAB Installers[/size] [size=2]
[/size] [size=2]click here to download](http://www.lakeridgesoftware.com/downloads/wisbardesktop.armv4i.cab)
P/S chắc phải làm lại bản Hướng dẫn chi tiết sử dụng WAD quá :slight_smile:
Những thứ khác liên quan đến phần mềm xin đọc kỹ chữ ký của wildcat
Clock nhìn cool nhỉ? :slight_smile:
Hổm rày em ko còn sử dụng WAD nữa vì cảm thấy nó chậm quá. Bi giờ có bản mới rồi + Wisbar Advance .17 nữa, thử cho hai đứa nó sống chung xem có cải thiện được tình hình ko? :smiley:
Mấy bản trước dùng chậm quá, không biết những bản mới này có cải thiện được đáng kể về tôc độ không nhỉ. WAD bản mới này nhìn cái dock của nó fê thật đấy.
Tôi thì chỉ khoái mỗi cái clock, những cái khác cài vào rồi lại phải gỡ ra vì chậm. Bác nào có cái clock kiểu như thía này thì share với.
Cài cái này mà ko chậm mới là lạ. Chủ yếu phù hợp với mấy bác yêu nghệ thuật muốn mông má con PPC của mình nhìn chiến một chút thôi.
Không những chậm mà quá chậm luôn, tôi cài thử lại phải down về bản 1.0.0.3
Hai cái WA .17 và WAD 1.0.0.4 cài với nhau chạy nhanh đấy chứ. Em đang tìm mấy cái dock trong suốt như kiểu cái dock của anh Wildcat giới thiệu đó. Ai có thì cho em với nhé
Email: banhbao87vn@yahoo.com
Các cái DOCK đó bác có thể tạo từ các file ảnh PNG trong suốt rồi converter qua TGA hoặc có thể chọn ở setting của DOCK cho trong suốt được mà :smiley:
May Bac oi !! Ban nay ko can Vung sao ?? em moi down ve …chua dam thu !!
Có chứ bác, bản nào chẳng cần vừng :smiley: vấn đề này bác PM cho em nhé :smiley:
Cai ban nay dung VUNG cu cugn duoc anh em ah !! minh vua thu hom qua thay OK …nhung ma co dieu hinh nhu bi loi cai gi do !!
Đã có bản 1.0 build 5, anh em nào test thử xem có gì mới không, cuối năm bận rộn quá, chẳng còn thời gian làm gì :frowning:
Đây là nội dung nâng cấp mới:
Enhancements
Bugs Fixed
Khoái nhất là có hiển thị đo sóng, notification…
Khiếp, sao ra nhanh thế… em mới làm lại con dell hôm qua, giờ lại hig hục cài lại… hãi quá đi mất . Nhưng fix được cái lỗi khi vào setting của WA2 thì out WAD là tốt rồi… em đang định hỏi xem có bác nào bị không hì hì :smiley:
Cái này càng nâng cấp càng chậm hay sao ấy ??? Chán qua…
em đã down bản 1.0.5 về mà không hiểu sao xem about nó vẫn là 1.0.4 >.< mà rõ ràng trước khi cài em đã xóa toàn bộ WA và WAD rồi. Xóa hết cả registry và những thứ gì liên quan. Bó tay !!!
Cho em hỏi thêm là cái face của analog clock thì mình lấy được ở đâu ạ em đang muốn có quả đồng hồ quá mà chưa bít làm. ^^
Mình thấy phần mềm này cài làm chậm máy hẳn đi, mà cũng chằng đẹp gì lắm sao các bác lại thích chú này quá nhĩ :slight_smile:
em cung như bác, nhưng máy em mới hardreset,vây chắccó vấn đề khi down thôi?!
còn về tốc độ, em lại thấy ngược với nhận định của các bác, nó nhanh mà, chắc tùy máy?! em dùng hx4700
mình cũng gặp tình trạng như các bạn là sau khi cài version của nó tự lùi về 1.0.04
Riêng về cái đồng hồ thì đến nay mình vẫ chưa mò được, mong các bác chỉ giúp
Cài cái này nó chỉ báo là 1.0.0.4 thôi nhưng mà các bạn xem lại ngày build của nó đi , ngày của mình là 17/01/06 , đó là bản build 5 , nó có đủ các chức năng mới , hai chức năng cho button , chỉnh được độ đậm của kim đồng hồ
Cài bản WAD build 5 và bản WA 2.4.1.19 chạy cực nhanh
HP 2750 còn chậm chứ nói gì HP 4700 bác.
