MS ActiveSync 4.5 beta
Tưởng chừng như bản 4.2 là bản cuối cùng khi Vistra ra đời nhưng với sự chậm trễ của Vistra và bản 4.2 đầy lỗi thì sự ra đời của bản 4.5 là tất yếu. Tiếng Anh kém quá, đành để nguyên văn vậy
• Faster file transfer speed and photo sync via Outlook are only available for Windows Mobile 5.0 powered devices.
• Remote PC Sync (via WiFi or LAN) has been removed due to Enterprise customer feedback around security issues.
• Customers using Microsoft Exchange 2003 Service Pack 2 with devices running the Messaging and Security Feature Pack for Windows Mobile 5.0 will benefit from the following feature enhancements included in ActiveSync 4.5: Direct Push Technology, local device wipe, and certificate powered authentication to Microsoft Exchange.
• Microsoft® Outlook® 2000 is not supported by ActiveSync 4.5 Beta 2. It is highly recommended that users upgrade to Microsoft® Outlook® 2003 messaging and collaboration client.
• Conversion of database files for use on a mobile device is not supported by ActiveSync 4.5 Beta 2. On previous versions, this feature was limited to devices running Windows Mobile software for Pocket PC 2003 and earlier.
• Conversion of font files for use on a mobile device is not supported by ActiveSync 4.5 Beta 2. On previous versions, this feature was limited to devices running Windows Mobile software for Pocket PC 2003 and earlier.
*Connectivity and synchronization may require separately purchased equipment and/or wireless products (e.g., WiFi card, network software, server hardware, and/or redirector software). Service plans are required for Internet, WiFi and phone access. Features and performance may vary by service provider and are subject to network limitations. See device manufacturer, service provider and/or corporate IT department for details.
Chi tiết ở đây
Cảm nhận đầu tiên:
  • Giao diện mới, đẹp hơn, nhanh hơn chút.
  • Vẫn bị lỗi khi kết nối internet qua sync, giống như bản 4.2
  • Cho phép sync qua WiFi giống như bản 3.8 nhưng chưa thử được
Có sync qua Wifi được đâu anh, nó ghi đây nè:
Anh thấy có có chỗ check giống bản 3.8 tưởng là được hóa ra không phải, lười đọc thật :smiley:
Cách đây không lâu đã có thông tin là MS kông tiếp tục phát triển Active Sync nữa cơ mà, hóa ra mấy tin đó là của hãng Con Vịt Cạp à :confused:
Thế không biết thằng này có sửa được lỗi đứt kết nối wifi nếu dùng WPA + WM5 + Intel Wifi controller không các bác nhỉ?
Đúng là không thể vào Internet qua sync được : " The page you are looking for cannot be found due to unknow error 0x80072f78 ". Tốc độ cũng không cải thiện gì mấy, sync khoảng 500 contacts mất 5p, được cái giao diện trông pro hơn 1 tí. Đành phải đợi thôi vậy.
Ai nói là bản 4.2 không vào internet qua sync được nhỉ! Mình dùng Exec, vào ầm ầm! thế là sao nhỉ! có gì nhầm lẫn ở đây không các bác!
Bản 4.5 beta PPC vào internet qua sync PC bình thường , mình chưa bị kể cả bản 4.1, 4.2
Bản 4.2 vẫn vào Internet được với Win03 còn Win05 thì không (thử với 2 máy T-Mobile MDA và T-Mobile Compact II)
Đúng là bị lỗi với các bản Update SP2+ của Windows XP. Nếu bác nào dùng bản 4.2 trở nên bị lỗi thì vào Regedit (của PC) để thêm khóa sau
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows CE Services]
“AllowLSP”=dword:0
Hê hê, cái Reg của bác Cường hay quá, một phát ăn ngay, thankx!
Em cài thử bản 4.5 vào, sync với MiniS, tự nhiên thì lỗi không sync được nữa. Tức quá đã remove đi (cẩn thận xóa hẳn các thư mục của MS activesync và vào registry xóa hết đi rồi), cài lại bản 4.2 thì bản 4.2 không hoạt động được, ngay từ khi cài lên.
Cài lại bản 4.5 thì vẫn lỗi, không sync được.
Trước đây khi vẫn còn sync được thì không thiết lập được cấu hình với exchange server để lấy mail. Phần kết nối với Jeyo để gửi và lưu tin nhắn cũng tịt luôn.
Các cao thủ ra tay giúp với, giúp với :frowning:
Em đã tự giải quyết được vấn đề sync. Nhưng với Jeyo Mobile thì vẫn chịu chết? Có cách nào không nhỉ? Chẳng lẽ phải cài lại Jeyo
Jeyo Mobile nó không hỗ trợ WM5 bác ơi. Nếu bác dùng bản WM5 AKU3.2 thì trong connection setting-> USB to PC bác thử uncheck mục Enable Advanced network functionality xem sao (Chắc con HP của bác không có đâu :p).
Mấy bác xài WM3 sướngbqua11 em xài WM5 nên k kến nối qua cáp đc.Em mới cài bản mới của bác nncuong sao cứ bị lỗi hòai vậy bác
