Presentation Controls
Smoothly navigate through Microsoft Office PowerPoint® and other presentations from up to 30 feet away from your PC.
Media Remote
Use for multimedia presentations and control digital entertainment from the comfort of your living room sofa.
Battery Life Indicator
You won't get caught with a dead battery—the Battery Status LED Indicator glows red when the battery is running low.
2.4 GHz Bluetooth® with First Connect Technology
Connect wirelessly right out of the box with 2.4 GHz Bluetooth®.
High Definition Laser Technology
Microsoft® High Definition Laser Mouse products are more precise, more responsive, and deliver smoother tracking.
Laser Pointer
Point out essential information during presentations with the laser pointer.
Innovative Industrial Design
The sleek and stylish design looks great on any desktop in your home or office.
Digital Ink
Give your presentations more impact by highlighting vital information on screen.
On/Off Switch
Turn your 3-in-1 device off to extend battery life even longer.
Magnifier
Point and click to enlarge and edit detail using the Magnifier*.
4-Way Scrolling
Scroll four ways for greater efficiency and comfort with Tilt Wheel Technology.
Carrying Case
Protect your mouse while you’re on the go.
Instant Viewer
Too many open items on your desktop? Click the scroll wheel button to instantly display your open windows, then point and click to select.
Customizable Buttons
Get quick access to the media, programs, and files you use most often with customizable buttons.
Laptop/Notebook Mobile
Compact and comfortable, our handy notebook and laptop products are designed for convenience and mobility.
Wireless Freedom
Give yourself room to move—wireless mouse and keyboard products let you work without worrying about tangled wires.
Five Customizable Buttons
In addition the media a presenter keys, has five buttons that can be programmed to do a variety of functions.
For a Microsoft® Windows®-based computer:
Computer/Operating System
Requires a PC that meets the requirements for and has installed one of these operating systems: Windows Vista® or Windows® XP.
IMPORTANT: For best results and Bluetooth® device compatibility, use the included Microsoft® Mini Bluetooth Transceiver. Service Pack 2 is required with Windows XP.
http://www.microsoft.com/hardware/mouseandkeyboard/ProductDetails.aspx?pid=085&active_tab=overview
