http://images.palmgear.com/software/screenshots/160x160/52120.gif
http://wiki.jmjeong.com/upload/2_MP23.PNG
http://wiki.jmjeong.com/upload/MP300.PNG
Công cụ hữu hiệu giúp các bác lên lịch làm việc, dung lượng nhỏ nên chạy rất nhanh, hỗ trợ copy’n paste…, mời các bác nghiên cứu thêm ở description phía dưới
Allow efficient management of the
events' and 'to do's' through common data sharing with the built-in
Datebook’ and `ToDo List’ applications. -
Support Category option for an
event' item as well as
to do’ item. -
Allow you to conveniently glance over the entire month for
events' and
to do’s’ with wide calendar screen and rotational icons. (Also support high-resolution icons) -
Filtering' function allows display of the
events’ and `to dos’ based on selected category and /or priorities. -
You can easily move or copy your
events',
to dos’ and/or `cells’ by Drag & Drop for each item. -
Small size of the application (only 81 kb) allows quick execution and less burden on memory management.
Better
readability' by allowing user option to select all description colors for
events’ and `to dos’. -
Allows option for user to selectively change colors for all items on the calendar.
You can also set colors of all calendar items.
Intuitive user interfaces and the pop-up menus make it easy for the user.
Support NVFS file system (Treo650, T5)
Provides `D-Day’ management.
Support category icon feature
Download
http://www.palmgear.com/software/act_redirector3.cfm/TYPEzip/PID52120/MonthPlanner3.0.7_All.zip
Thuốc thang
Chicken Link
U: shareordie
P: nosteal
