Lại có PocketMusic Pro 4.2.6 roài
PocketMusic Pro 4.3 nghe nhạc cực đỉnh!!!
Lại có PocketMusic Pro 4.3 roài
http://rapidshare.de/files/24291804/PocketMusic_ver4.3_Bundle.rar.html
Thằng này nghe nhạc thì đỉnh nhất. Em đang dùng v4.2.1 mà thấy hay quá rồi.
Không biết vừng mè thế nào nhẩy:D :smiley: :smiley:
Hà hà, nó cho update từ bản 4.2.1 các bác ah. Thấy hỏi có update không, sau khi update thì nghe luôn, cực phê, không thấy hỏi serial gì sất. Giao diện Winapm đẹp hơn nhìu.
Em có hai skin tuyệt đẹp, cực pro, bác nào cần em gửi cho.
pplication Description
PocketMusic Player Bundle application will turn your Pocket PC into a portable media player with rich features:
  • Listen MP3, OGG, MP1, MP2, WMA, WAV music files from → Pocket PC main memory → Storage card (Multimedia card, Flash memory, SD card, etc.) → Local network → Internet
    o Enjoy audio books → Bookmarks support, Audible audiobooks support
  • Use Pocket PC as a car player. Listen your favorite digital music from storage cards, or listen Internet radio! → Optimized, special Landscape mode
    PocketMusic
Go to sleep and wake up with your favorite music → Timer feature → Alarm feature
  • Enjoy music with 10-band Equalizer for all media formats and Extra Bass option
    o Have fun with Crossfading and Gapless features
  • Personalize interface with thousands of supported Winamp 2.x skins
    PocketMusic
Have fast access → PocketMusic Today item - control music playback directly from Today screen
PocketMusic
  • Organize your music library and create playlists with Advanced Playlist Organizer
    o Get more power and control music with hardware button mapping feature → Map such actions as Play, Stop, Pause, Volume Up/Down, Mute, Load Files (or any other) to Pocket PC’s hardware buttons
    PocketMusic
  • Save battery life, listen music longer than ever “Turn off screen” feature. Map this action to any hardware button or use Auto-Turn Off feature to automatically turn off the screen while music is playing (timer from 5 sec to 3 min).
    PocketMusic
    Specials:
User interface in English, German, French, Spanish, Italian
Compatible with Pocket PC 2002 and Windows Mobile 2003 devices. Plus, special support for Windows Mobile 2003 Second Edition.
He he, em gửi bác roài
Bác download 2 files em gửi rồi copy vào Mydevice → program Files → PocketMusic → PMSkins
Chạy PocketMusic → options → Player Options → Skin (Phía dưới màn hình, dùng thanh cuộn sang phải) → Select Skin
Các bác cần xem và down Skin vào đây nha
http://www.megaupload.com/?d=43IY5THL
:smiley: :smiley: :smiley: :smiley:
He he, em UP tất cả lên đây (tất tần tật). Các bác vào lấy về chơi nha
http://www.megaupload.com/?d=K199DTZC
Hoặc ở đây
http://rapidshare.de/files/21985530/PocketMusic_Bundle_v4.2.6.rar.html
Em đang gởi cho bác, cả bộ luôn nhé, đầy đủ cả. Chờ tí bác :smiley: :smiley: :smiley:
cách Upload và download trong megauplaod các bác xem đây nha
http://www.xahoithongtin.com.vn/index.asp?ID=0&subjectID=7996
Còn rapidshare thì đây
http://www.echip.com.vn/echiproot/html/2006/so342/hoidap.html
Tôi tải 2 cái skin của bác về và cóp vào skin của pocket pro rồi nhưng sao ko thấy nhỉ? Bác nào có thể giúp tôi ko?
skin này chỉ hổ trợ cho 02 mini thôi bác ạh, bác nào xài 02s hay i thì đành chịu thôi…
Có khó khăn chút, soft thì chuyên nghiệp rồi đấy nhưng nhiều “phím lệnh” nhỏ chi chít làm đểm chỉ hơi khó khăn (nhầm chỗ hòai, những phím nằm sát kẹt thì thua luôn).
Ừh, cái này em thấy nghe nhạc quả thật hay nhất! dùng các chương trình khác nhau cùng nghe một bài mới thấy cái này hơn hẳn! Nhưng cái em ưng nhất này lại rất hay giật và hay bị treo máy khi nghe mới điên chứ! Bác nào có cách khắc phục khônng ah?
tôi dùng bản mới này sao vào Equalizer chỉnh xong, lần sau vào toi luôn, không lưu lại setting được?
các bác cho em hỏi bản này có bị lỗi mất đăng ký khi mình kết nối internet ko?
nếu bác nào cần xài mà kô bị mất đăng ký thì xài vừng của mình đây ,tha hồ mà xài hết đời luôn (version 4.2.6 thôi):stuck_out_tongue:
Have funs
Phiên bản mới 4.3 có vẻ chạy ổn hơn trên SE, bản cũ 4.2.6 thì rất hay bị treo. Đã chạy thử playlist khoảng 20 bài trên bản 4.3 này thì ngon trớn, không như bản cũ chỉ khoảng 3 bài là phải “chọc đít”:mad: . Không hiểu các bác chạy trên SE có thấy vậy không?
À, tớ còn bị vụ này: Tạo một playlist (add folder trên thẻ nhớ)xong, thấy không khoái bài nào đó thì xóa trong playlist rồi xóa luôn cả trên thẻ nhớ, nhưng khi chơi lại playlist đó thì bài vừa xóa đó vẫn còn hát rầm rầm:eek: thế mứoi ghét, kiểm tra lại trên thẻ nhớ thì bài hát đó không có, nhưng vào danh sách của PM vẫn ngon. Chẳng hiểu sao? Các bác có cao kiến gì không và cho hỏi mình xóa rồi thì nó lấy data ở đâu ra mà hát thế nhỉ??? :mad: :stuck_out_tongue:
bản 4.3 hay bản 4.0.3 vậy các bác
Đã có bản mới PocketMusic ver 4.3.2. Các bác Nhào do đi nào!
Còn cần đủ đồ nghề thì sang MF lấy:p :smiley:
cần j phải sang đó bác cần thì PM cho em
nó có khác biệt gì hơn so với bản 4.3 không vậy bạn,theo như mình thấy ở bản 4.3 không khác gì sovới bản 4.2.6 cả,cài vào chỉ tổ nặng máy thêm thôi,những soft này phải cài trên device or storage chạy mới OK đựơc nhưng tốn MB wá
CHo minh voi nhe toro_snow_angle@yahoo.com. Thanks
Cái này em chưa bao giờ register dc, toàn báo lỗi wrong serial No. không àh. Bác nào chịu khó bỏ tí thời gian hướng dẫn cách đăng ký cho anh em thưởng thức với!
Các bác cho hỏi luôn, tôi dùng bản mới này sao không load được list bài hát nhỉ? Thanks các bác chỉ giáo giùm!
