Các bác chú ý dùm mình, **KHÔNG DÙNG ITUNES **nha.
Tớ tìm hết trên net roài mà chả có trình nèo **chuyển Photo sang Ipod **hết, toàn chuyển ngược lại thì đầy, ai biết làm như thế nào không, DL ở đâu ? full càng tốt.
bùn ghê, kô ai giúp mình à ?
k dùng Itunes thì bác dùng cái gỉ nhỉ???
mà của bác 80G mà đầy thì hơi lạ.có thể bác chứa dữ liệu gì sao
cái anapod explorer cài rồi nhưng nó không “work” với con này. Ai co cao kiến gi` kô ?
http://www.imtoo.com/ipod-computer-transfer.html
crack thì bác vào crackzplanet.com xem có ko
Hay wá thx bác nhìu, đang dl ne`
ImTOO iPod Computer Transfer
ImTOO iPod Computer Transfer is premium iPod transfer software for iPod music, video and photo transferring. It can transfer iPod music, videos and photos from iPod to computer (iPod to PC), backup iPod to PC quickly and smoothly. And concurrently, it’s also a computer to iPod transfer tool which can transfer iPod music, videos and photos from PC to iPod.
Featuring multiple functions, ImTOO iPod Computer Transfer is a perfect, easy to use iPod transfer and iPod backup tool between iPod and computer for iPod user like you.
This iPod backup software helps you transfer iPod, iPhone music, video, photo, and podcast to computer local disk, back up iPod to PC, and vice versa. Moreover it supports file transfer from iPod to iTunes.
ImTOO iPod to computer transfer can copy and transfer music/videos among several iPods. With ImTOO iPod Computer Transfer, you will find connecting your iPod, iPhone and computer is so easy!
**It supports not only importing photos from PC to iPod, but also exporting photos from iPod to PC.
It can be easily used like a portable hard disk to manage your iPhone content, import and export files between iPhone and PC.
All functions for iPod are applicable to iPhone as well.
Imtoo_ipod-computer-transfer_2.0.93.0509 mới nhất, “cờ-rờ” roài, ai cần “vừng” PM nha.
cạch, sync hình cho Classic tự DUMP rồi tắt ngúm cái PC, thử 2 lần sợ quá, không dám chơi típ, lỡ hư hdd thì toi.
connect vô con nano3 chỉ thấy 1 loạt file bmp giống nhau, thumb cũng giống nhau luôn, vậy mà export sang local c:, d:\ thì thấy đúng hình
Sync vô classic thì dump, còn nano3 thì không ép phê << hình nhưng kô tương thích lắm hay sao á.
**Tiếp tục nhờ vả các bác rồi **
_thế dùng IT cho rùi đi pác!chi mà cần phải cực khổ rứa!
rõ khổ, ai chả bít thé :-? nhà tui làm DV máy móc “đóng băng” hết gòy, vậy mới tìm cách khác mà lị, dù j cũng cám ơn cái “tối kiến” của bác dzai
