Firmware 2.17.7.2 WWE Cingular 8125!!!
Firware dùng cho Wizard or Cingular 8125 sử dụng chip OMAP850 200Mhz
hxxp://forum.xda-developers.com/viewtopic.php?t=47052&postdays=0&postorder=asc&start=0 hihi… firmware này đã cook rùi chứa
–Calibri/Segoe fonts from Vista/Office 12 installed in Windows directory(You’ll need to use a 3rd party app to change the system or other font)
–một số ringtones mới chưá trong thư mục \Windows\Rings
–Origami themes khá đẹp hxxp://www.amtech-vn.com/showthread.php?p=204799#post204799
–Omapclock.exe installed in \Program Files\OmapClock
–Customized links to 3 OmapClock clock speed settings: 200Mhz, 240Mhz, 252Mhz (You can select these by going to START->PROGRAMS. You will see "Clock200, Clock240, Clock252. These can be mapped to a hardware button) <= cái này giống như OC PPC ah
–Removed the extended ROM customizations that add Express mail and Good mail
