ScorePad 5.0 B56 : Medium
UPDATED 12/2/2004 8:49:00 AM CST
Scrabble 1.2 : Medium
UPDATED 2/15/2005 12:30:00 PM CST
ScreenCare 2.9.5 : High
UPDATED 1/2/2005 12:15:00 AM CST
New version.
ScreenShot 2.2 : Medium
UPDATED 12/17/2004 2:00:00 PM CST
SDS Time 6.4 : Medium
UPDATED 1/24/2005 7:30:00 AM CST
Secret! 3.2 : Medium
UPDATED 4/5/2005 9:37:00 AM CST
Shadow Plan 4.0.5 Beta : Medium
UPDATED 12/24/2004 12:57:00 PM CST
Due to OS issues, there is a slowdown using the link manager. For most users, this should not be an issue.
Shanghai 1.1 : Medium
Silverscreen 3.3 : Medium
SimCity 1.7p : Medium
Version 1.7p was never released by the company but if you can find it, it does work.
Skyscape : Medium
No Version Available
SlovoEd Dictionaries 4.14 : Medium
UPDATED 3/28/2005 12:23:00 PM CST
SmartList To Go 2.603 : Medium
UPDATED 3/11/2005 8:27:00 AM CST
This version will work, but it is not a current version that is supported. The current version is 3.002.
SmartList To Go 3.002 : Medium
New version.
SmartMovie 2.50 : Medium
Snails 2.1 : Medium
UPDATED 2/27/2005 12:15:00 PM CST
From user, “It works great. I think the error: ‘Caused MemoryMgr.c,Line:3811,NilPtr error.’ is because of not having enough free ram to run game. I have game on my SD card and I have 4M free ram and I never encounter this error. I copied a large document to my palm giving me only 1M free ram and I still did not recieve that error.”
SnapCalc5 5.6 : Medium
SnapperMail 2.1.0 : Medium
As usual, works on anything. Works well on anything.
SoftReset 1.0 : Medium
UPDATED 12/13/2004 12:30:00 PM CST
Sol Free 4.30 : High
Solitare 3.07 : High
SoundRec 1.051 : Medium
Some users having problems recording to their SD card, though.
Speedy 4.0 : Medium
Splash Clock 1.06 : Medium
Splash ID 3.22 : Medium
UPDATED 3/3/2005 9:25:00 AM CST
Updated version.
Splash Money 3.02 : Medium
UPDATED 2/18/2005 12:00:00 PM CST
From Treo 650 user, “I found a bug in the current released version I was using v3.02 whenever I’d run a search for a transaction (using either FindXXXX or the default OS search function) and then click on the result, to open that transaction, my treo 650 (GSM unlocked) would soft reset itself. But I got my hands on a beta release v4.0b1 and this bug has been eliminated.”
Splash Photo 4.21 : High
UPDATED 3/11/2005 12:12:00 AM CST
Splash Shopper 2.61 : Medium
UPDATED 3/3/2005 9:26:00 AM CST
Updated version.
Splash Wallet 5.08 : Medium
SSManager 1.0 : Medium
Bundled with Matrix Screen Saver 2.01.
StarAlliance 4.0.3 : Medium
UPDATED 1/18/2005 12:30:00 PM CST
Stock Manager 4.40 : High
320x320
Strip 1.0 : Low
UPDATED 2/2/2005 11:00:00 PM CST
From user, “The main functionality works, but it soft-resets the unit when you use the password generator.”
SuperMemo 1.1.1 : Medium
UPDATED 3/4/2005 10:58:00 AM CST
SuperUtility 6 : Medium
Symantec Anti Virus for Handhelds 2004 Version 3.0 : High
If you have problems installing, there is a fix posted here.
T3X : Medium
Verfied by developer.
TAKEphONE 6.50 (034) : Medium
4/5/05: From user, “Takephone 6.50 doesn’t seem to handle timed pauses. Hangs on white screen when dialing a number with a timed pause forcing a soft reset. Same number dials fine with a hard pause.”
2/27/05: New version should be compatible.
Tantric 1.0 : Medium
Tarason Pharmacopoeia : Medium
From user, “Tarascon Pharmacopoeia works on the Treo 650. The subscriber must make sure he selects Treo 600 as the intended device and then download the zip file it associates with. Works on both handheld and memory card with no problems as of yet.”
TealBackup 1.11 Beta : Medium
UPDATED 4/5/2005 9:34:00 AM CST
New beta version. From user, “i made hard reset and used tealbackup 1.11beta to restore - all is ok.”
TealInfo 4.21 : High
Latest version is 4.32.
TealLock 5.30 : Medium
UPDATED 3/4/2005 11:00:00 AM CST
TealPaint 6.40 : Low
Need some other users’ input. From one user, “I have been trying everything I know to eliminate the jaggies when drawing a curve with TealPaint on the TREO 650. No luck. Do you know anything? Their tech support is non-existent. I was one of the first to get the 650 and immediately loaded TP and contacted TealPoint. Zero follow-up on their part. I have adjusted the settings, but maybe I am missing something. It would be nice to be able to draw a nice smooth curve.”
TealScript 3.60 : Medium
New version. Reported to fix HotSync issues with TealScript active.
Tetris Classic Game Pak 1.3.1 : High
Tetris-otP 1.0 : High
No link found.
Text Twist 2.02 : Medium
TextPlus 5.6 : Medium
UPDATED 3/9/2005 7:21:00 AM CST
3/9/05: Appears there is a conflict between this and Vindigo 2.63.1.2 on the T5. From T5 user, “I have found that if TextPlus is enabled globally (which it must be if it to be of much use) Hotsyncs tend to crash during the syncing of Vindigo. If TextPlus is not enabled globally, Hotsyncs complete ok, but all the Vindigo data seems to be missing. If I remove TextPlus from the T5, I find everything works fine.”
3/2/05: New version. From user, “MUCH better than WordComplete. Most functions work consistently. A little confusion with Versamail when choosing a recipient for an email. But otherwise very helpful and time-saving program.”
Thought Manager 2.78 : Low
320x320
TiBR Pro 1.52 : Low
TideTool 2.2 : Medium
320 x 320 Application
Tiktok 2.22 : Medium
UPDATED 12/2/2004 4:46:00 PM CST
Times 2.1 : Medium
Titrax 4.06 : High
From user, “This little GPL gem is a great way to track your time. Tested every feature and found no problems. No support for 5-way, though. Works with both Calendar and DateBk5.”
Today 2.2 : Medium
Seems to work just fine. Default skins do not look good.
ToDo Plus 3.60 : Medium
UPDATED 3/23/2005 12:12:00 PM CST
New version. Verified by users to work.
TomeRaider 2.88 : Medium
TomTom Navigator 2004 : Medium
The only problem on the Treo 650 is when the phone rings, the navigator 2004 software quits and I have to restart.
TopSecret 3.60 : Medium
320x320
TrackerDog 1.51 : High
Latest version is 2.11.
TrackerDog 2.02 : Medium
Tradewinds 1.02 : Medium
Traffic 1.13 : High
Latest version 1.2.
TravelDeluxe 2.01 : Medium
TreoAlarm 0.95c : Medium
Updated version.
TreoGuard 1.6.01b : Medium
Beta release 1.6.01b includes Treo 650 compatibility. Latest release 1.5.03 has some issues. Download beta here.
TreoHelper 0.56 : Medium
It works on the Treo650 the same way that it worked previously on the Treo600.
Tricorder 2.1.1 : Medium
Trip 3.04 : Low
Caution: Existing database does not work if you have to perform a hard reset. You will have to create a new database.
starting with a new database it works fine."
Tube 3.23 : Medium
UPDATED 3/4/2005 11:01:00 AM CST
3/4/05: From user, “I haven’t noticed the memory remnant problem that a previous user mentioned, then again I don’t use powerrun since it’s unnecessary for tube: as it states in the manual, you only have to leave the main app on the palm device while all the hefty maps can be stored on the memory card in 1 of 3 specified directories.”
12/17/05: From user, “Due to the famous memory issues, I keep it on my SD card, and access it via PowerRun. Most times this works fine. However, other times, after use, it will leave half of itself in memory, forcing me to delete and reinstall it.”
Ultrasoft Brainforest 3.08 : Medium
320x320
Ultrasoft DataShield 1.4.6 : Medium
UltraSoft Money 4.2 : Medium
New version released to improve compatibilty with T5 and to resolve issues with Treo 650.
Undupe 1.9.3 : Medium
Intermittently requires a soft reset when doing an exhaustive search and remove, but I can live with it.
Uninstall Manager 2.62 : Medium
New version. Users have verified compatibility.
UPIRC : Medium
VeriChat 2.58b : High
UPDATED 2/7/2005 10:40:00 PM CST
Versamail 3.0 : Low
UPDATED 3/2/2005 12:30:00 PM CST
From user, “Although palmOne swears by this program, and I admit I still use it, its dependability for email is in serious question. Error messages abound when trying to send mail. Receiving email seems to be no problem. SMPT setting options are limiting for many POP accounts. I would welcome feedback from others on this application.”
Versions 0.92 : High
Vexed 2.1 Beta 1 : Low
VFSMark 1.1 : Medium
ViaMichelin Maps and Route Planning 1.0 : Medium
Once you get it running - you have to use the Files application to rename or create a folder called VMCarto_Maps on Internal memory or SD card to put your maps in. Full hi-res screen
Vindigo 2.0.1.0 : Medium
Vindigo 2.63.1.2 : Medium
UPDATED 3/9/2005 7:25:00 AM CST
3/9/05: Appears there is a conflict between this and TextPlus 5.6 on the T5. From T5 user, “I have found that if TextPlus is enabled globally (which it must be if it to be of much use) Hotsyncs tend to crash during the syncing of Vindigo. If TextPlus is not enabled globally, Hotsyncs complete ok, but all the Vindigo data seems to be missing. If I remove TextPlus from the T5, I find everything works fine.”
3/2/05: From another user, “Works flawlessly so far. I have not had any of the hot sync problems you mentioned.”
2/2/05: From user, “I find that Vindigo (latest version, which is 2.63.1.2; July 6, 2004) gets screwed up during hot sync and has to be reinstalled. this happens about 1 in 5 hot syncs, and doesn’t respond to any of the measures I’ve taken. I’m keeping ~10 megs of free memory on the phone, but this doesn’t solve the problem. I suggest that you should move it from medium to low. I communicated with their tech support, but they did not have a fix available.”
Warfare Inc 1.2 : Medium
Wassup 1.4.4 : Medium
Web Confidential 1.4 : Medium
320x320
Wordsmith 2.2.24 : Medium
WorldMate 2004 (9.3) : Medium
Xiino 3.3e : Medium
Yahdice 2.01 : High
YAPS 2.5 : Medium
320x320
ZagatToGo 2005 (3.03) : Low
UPDATED 3/7/2005 7:34:00 AM CST
3/7/05: From user, “I’ve tried Zagat to Go version 3.03 (2005 version) and found that it works until you register it, so you can use ver. 3.03 for 14 days without registering. When you register the program it will crash the Treo 650 and reboot the device! I have been asked by ZTG tech support to revert back to Zagat to Go Ver. 2.0 the 2004 version which should work fine.”
2/27/05: Update has been released and now works.
12/2/04: Vendor working on an update.
ZLauncher 5.11 : Medium
UPDATED 3/3/2005 9:28:00 AM CST
Updated version.
