Chào các bác. Em vừa mua 1 chiếc Raymond Weil automatic ở trên amazon (cụ thểla dexclusive.com, review cuả nó là 10k trong đó 96% positive). Nhưng khi vào trang chủ của RW để check số serial (trong phần register) thì nó báo serial not recognized. Vậy các bác cho em hỏi là liệu đây có phải hàng authentic không. Bên ngoài thì trông rất đẹp, tinh xảo,kim chạy mượt mà. Thanks các bác ạ.
Có phải số serial thế này ko
[ATTACH=full]471225[/ATTACH]
Vâng đúng rồi bác. Register nó trên website nó báo ko recognized, nhưng cũng 1 cái RW khác mua ở AD thì lại register successfully, vậy là sao ạ
Mà con của bác cũng 2837 à, bác mua ở đâu vậy, bao nhiu ạ, của e là 2837-00609
[size=4]WHEN I TRY TO REGISTER TO THE RAYMOND WEIL CLUB, I AM TOLD THE SERIAL NUMBER OF MY WATCH IS NOT VALID. DOES THAT MEAN MY WATCH IS A COUNTERFEIT?[/size]
Sometimes the system does not recognize a serial number but that does not mean your watch is a counterfeit. If you need any assistance on that matter, please contact the RW Club at rwclub@raymond-weil.ch and attach a photo of the back of the watch showing the serial number or copy of the guarantee card. The RW Club will then take care of your registration.
[size=4]I CANNOT FIND MY WATCH ON YOUR WEBSITE; DOES THAT MEAN IT IS A COUNTERFEIT OR A DISCONTINUED MODEL?[/size]
The fact that your watch does not appear on our website does not necessarily mean it is a counterfeit or a discontinued model. Indeed, our website displays a selection of all RAYMOND WEIL watches available around the world: some references may not appear on our website but nevertheless be available through our network of authorized dealers.
If you are concerned with the authenticity of your watch, please make sure you bought it from one of our authorized dealers and were given the warranty card bearing the name and address of the seller, as well as its stamp and the date of purchase. Your watch should also bear a unique serial number engraved on the back of the case which guarantees its authenticity. If you still have doubts, you can use the Contact us form below to send us a message, including the serial number of your watch.
Thế cụ kiểm tra bằng cách nào ạ. Em cũng ko tìm thấy v349768 luôn
