Ứng dụng tuyệt vời để play các file Multimedia cho Pocket PC/Palm.
Phiên bản cho Palm đã hổ trợ WMV Format, nhưng chưa có tiếng (Cảm ơn bác Ilovemypalm).
Supported file containers
AVI (*.avi)
Matroska (*.mkv, *.mka)
MP4 (*.mp4, *.m4a)
Ogg Media (*.ogg, *.ogm)
ASF (*.asf)
Supported audio codecs
Mpeg 1 LayerIII
AAC (Advanced Audio Coding)
Ogg Vorbis
Musepack
Windows Media Audio (on Windows Mobile devices)
AC-3
AMR
Adpcm, uLaw
Supported video codecs
DivX
XviD
MPEG4-SP (plus B-frame support)
MPEG1
M-JPEG
Windows Media Video (on Windows Mobile devices)
Có gì mới trong bản nâng cấp.
version 0.66: 2005-07-08
+plugins only loaded when needed
+amr nb/wb audio decoder
+mp3 xing/vbri vbr info reader
+“Landscape” by Mobile Stream support on Sony CLIE NX/NZ/TH
+Sony HHE plugin. THANKS to Mobile Stream for reverse engineering GE2D API!
+Zodiac plugin using ATI Imageon hardware video decoding and 2D acceleration
+AAC plugin memory and speed optimizing (and fixing 5.1 channel support)
+ffmpeg plugin (video only)
+icecast support
+asf http streaming
+ogg/ogm native player buffering (saves dynamic memory)
+tremor vorbis decoder with high-accuracy (default with WinCE)
+merged .mpg file support (timestamps restart inside media)
+Sony remote control keys support (Thanks to aplus)
+WMP10 support (WMA/WMV) (except on devices with 2700G)
+PalmOS: shortcuts and preferences in main menu, key navigation (Thanks to Dan Walkowski)
+PalmOS: support for ROM storage (example with JackFlash)
+PalmOS: left/right direction buttons skip songs and seek when holding down for longer
+PalmOS: form savebehind disabled (saves dynamic memory)
+PalmOS: T|T T|2 memory tweak
+PalmOS: white borderless fullscreen and tripple buffering tweak on some devices
+PalmOS: battery manager override tweak
+PalmOS: WMMX optimized motion compensation code added
+PalmOS: sysAppLaunchCmdOpenDB & sysAppLaunchCmdCustomBase launchcodes for launching media files
+WinCE: 2700G and ATI Imageon hardware released in background
+WinCE: Musepack plugin added to main install (AC3 removed to separate plugin)
+‘fill screen’ zoom option
-zero & duplicated chunk avi handling (fixes a/v sync with some tv records)
-non interleaved avi handling
-LifeDrive: action button fix and audio distrotion workaround for silent parts
-QDA700: smartphone audio fix
-Treo650: keyboard backlight light fix
-PalmOS: frame dropping bugfix
-Sony: jog keys fix
-.mov and .asf file reader fixes
-PalmOS: alarm suppressing fix
-avi seeking fix
-PalmOS: plugin relocation not making databases ‘dirty’
-PalmOS: low memory situation fixes
-WinCE version working again
-2700G: display flashing and freezing fix
-WinCE: file associations fix (ringtone on Smartphones, downloading from web)
-many minor bugfixes
Hi!
Khó chọn quá. Không biết cụ thể là file nào dùng cho mìng. Tôi tải tệp: tcpmp.src.0.66.tar xuống thì nhìn bộ nhớ sau khi copy vào PPC thì vãi cả linh hồn vì tới gần 15Mb. Hi nếu chỉ chơi nhạc không thì hy sinh ngần ấy được. Còn tải mấy cái tệp kia xuông thì tòan ở dạng địa chỉ: tcpmp.setup.0.66.exe site thôi chứ ko có xài được.
Cái trang download của nó rõ ràng như thế mà các bác còn tải sai sao? Trên mỗi phần đều có tiêu đề ghi rõ các file dùng cho Palm hay WM (nếu cho WM thì ghi rõ là cho PPC hay smartphone luôn); là soft hay là plugins. Ngay cả tên file đã nói lên tất cả rồi mà.
Bản này rất hay, mình chờ đã lâu rồi vì sau khi UP ROM lên WMP 10 thì Beta Player trước kia không xem được file WMV.
Không biết các bác nghĩ sao chứ em thấy WMP 10 chán quá:
Menu rối rắm, muốn play file video phải vào menu->library->update->search->done->my videos->all videos->play,nhức đầu quá.
Dùng phím tắt tăng giảm âm lượng hay Fast Forward ở chế độ Fullscreen đều bị zoom nhỏ lại, phải chọn Fullsrceen lại.
Không chỉnh được Brightness, contrast, saturation…
XHuy** đã nhắc rồi mà bạn! Trên trang download đó có ghi rõ cái nào dùng cho Palm, cái nào dùng cho Windows Mobile, cái nào là plugins mà bạn!
Với O2 mini của bạn là Pocket PC dùng hệ điều hành Windows Mobile 2003 SE, bạn nên chọn file exe cho dễ tiến hành cài đặt từ PC. http://pic18.picturetrail.com/VOL943/3763031/7766310/103945850.jpg
Thằng TCPMP này xài thấy ko tốt mấy so với soft Album có sẵn trong O2 II , lúc play file .3gp thì bị giật,nhòe và ko có tiếng , còn thằng Album chạy tuốt, các đuôi khác chưa thử hết
Các bác theo link này mà down, tớ cũng down được rôi, lúc nãy vào link kia toàn ra file html, cái này hình như là link dự trữ của nó !!! http://picard.exceed.hu/tcpmp/0.66/
Dù dùng Palm hay PPC thì chỉ cần TCMP đổi cái giao diện đẹp hơn thôi, thì mình sẽ bứng ra được một mớ Player, chẳng những không mất đồng nào hết mà còn được tiếng là xài soft có bản quyền nữa. Hay quá.
đúng rồi đó, em thấy ko tốn tiền mà còn dùng bản quyển nữa, có tài khoản chùa nhưng vẫn giống như lén lút phải không các bác, em chọn cái free cho nó chảnh,hehe
[QUOTE=dihuta] Ứng dụng tuyệt vời để play các file Multimedia cho Pocket PC/Palm.
Bác ơi, làm thế nào để xem wmv trên Palm với phần mềm này???
