XDAIIs-asia đã có rom mới 1.40 (Bản chính thức)
XDA2s đã co rom chính thức phiên bản 1.4 thông tin ci tiết xem tại http://www.seeo2.com/user/template/SoftwareUpgradeMenu.vm?strImei=353030001237015&strDPRID=65653&DeviceID=93
Paste cái thông tin ra đây cho bà con xem qua vậy.
Introduction
Since the launch of Xda IIs, a few enhancements have been made to the device. This System Software Upgrade consolidates all enhancements into a single ROM upgrade. O2 encourages Xda IIs users to upgrade their devices to this system software.
English ROM
ROM: 1.40.00 WWE
Date: 03/10/05
Radio: 1.12.00
Protocol: 1337.42
ExtROM: 1.40.923 WWE
MMS: 2.0.0.21
BT: 1.0.0 Build 3900
You can check the core software versions running on your device by going Start > Settings > System tab > Device Information.
WHAT’S NEW?
New features - Windows Media Player 10, support MP3 ringtone, manual band selection
Latest updates on Microsoft Windows Mobile - Microsoft AKU(*) release 2.6 for Windows Mobiles 2003 Second Edition
MMS client - MMS client upgraded to 2.0.0.21 with improvements in interoperability
Radio software - Tested in major operators network in Asia. Improvements on GRPS and GSM performance.
New and updated operator network settings ¡V New additional operator settings for CTM (Macau), Orange (Thailand), Peoples (Hong Kong) and Sun Cellular (Philippines)
Resolutions to known issues
Radio will no longer automatically switched Off after Autoconfig with specific steps
Optus Zoo - CSD Line Type set to 9600 bps (v.32) and Non-transparent
Vodafone - the GPRS session will no longer be disconnected automatically if there is no data transfer for 3 min
Occasion call volume fluctuates when in move
Fixed failure in MTSMS during SDCCH handover
Fixed hang when trying to xbackup to a write protected SD card
REQUIREMENTS BEFORE UPGRADE
Microsoft Windows 2000 or XP with ActiveSync 3.7.1 or later. Other operating systems are NOT supported and may result in damages to your devices.
SPECIAL NOTES
  1. All data and applications will be lost. Please backup data before the installation. Reinstallation of
    third-party applications will be required.
  2. Once being installed, previous ROM cannot be restored. Should problems happen during or after the
    installation, the device may require servicing in O2 service centres.
PRECAUTIONS:
  1. Make sure battery power of your device is fully charged
  2. Reset your device and close all running applications prior to upgrade
  3. Restart your PC and close all applications prior to upgrade
  4. Connect directly to the USB port of your PC. Using a USB hub may affect ROM upgrade process
  5. Do not interrupt the ROM upgrade process
  6. Do not use other applications on your PC during the ROM upgrade
(*) AKU = Adaptation Kit Update
Disclaimer
This software is distributed without warranty. Please read the EULA carefully for terms and conditions. O2 is not liable for any personal data loss on the product during the installation of this utility.
Ko có pass để down, trên xda-developer thì chậm như sên, bác nào có up lên cho anh em xài với. Cảm ơn trước.
Đang lúc định cài lại máy thì có bản ROM mới phê qua đi mát.
@Hung_ng: lấy pass em trên đó mà sài:
caohung1985
Pass: 123456
There has been a temporary problem with our system. Please check with us later or contact our technical support at O2supportAsia@o2.com.
Lỗi không down được từ website của hãng rồi.
Hay quá, các bác up đi rồi có gì thông báo cho anh em biết với nhé. Nếu bản này không bị lỗi NO SOUND, NO BUGS thì tuyệt vời quá
Thôi em chả đợi nữa tự mình làm chuột bạch thí nghiệm cho nhanh.
Up ROM bằng laptop cho nó đỡ sợ mất điện giữa chừng :smiley:
20 nữa em sẽ làm báo cáo các bác về ROM mới.
Xin hết ạ :smiley:
Đã load về và cài… nhưng chỉ biết phát biểu một câu => Buồn và bực
Load về cài cứ đến 95% Update EXT coi như treo luôn con PC điên hết cả người… làm đi làm lại 3 lần đều bị thì ra trong lúc Update mở các chương trình khác nên nó treo luôn PC khi up EXT đến 95% => không mở nữa ngồi đợi xem sao…
Sau khi cài OK hết tất cả … bắt đầu mở ra test tưởng là ROM do O2 cung cấp chắc đồ xịn chứ không nhứ mấy bác “buôn lậu” trên xda-developers ai dè… vẫn thế Theme mặc định lại còn xấu hơn nữa … màu nhạt thếch mở WMP10 ra nghe sau đó tắt đi coi như câm luôn tưởng sao chứ thế này cho về vườn luôn… đang bực cóc thèm up lại ROM cũ nữa … điên hết cả người… khuyên các bác đừng up cho mất công nữa nhé
Đã mở EXT_ROM ra kiểm tra … nhiều kinh khủng: 15,3Mb hic hic … có lẽ phải up lên để anh em ngiên cứu thôi … đang gửi vào hòm mail theo chữ ký của em … các bác nào thích nghiên cứu thì lấy về nhé hic hic
;Remark
[Default]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIAWWE-19May05.reg.CAB
CAB: \Extended_ROM\O2_default_140921.sa.CAB
EXEC:\Extended_ROM\UpdateStartMenu.exe
RST: Reset
[1O1O]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIA1010-19May05.CAB
CAB: \Extended_ROM\1O1O_ALL_140921.sa.CAB
RST: Reset
[3-DUALBAND-]
CAB: \Extended_ROM\default.sa.CAB
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIA3DualBand-19May05.CAB
CAB: \Extended_ROM\3-DUALBAND_ALL.sa.CAB
RST: Reset
[AIS]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIAAIS-19May05.CAB
CAB: \Extended_ROM\AIS_ALL_100104.CAB
RST: Reset
[Celcom]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIACelcom-19Mayr05.CAB
CAB: \Extended_ROM\Celcom_ALL.sa.CAB
RST: Reset
[ChungHwa Telecom]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIACHT-19May05.CAB
CAB: \Extended_ROM\CHT_ALL.sa.CAB
RST: Reset
[CTM]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIAMacauCTM-19May05.CAB
CAB: \Extended_ROM\Macau_CTM_ALL_131922.sa.CAB
RST: Reset
[DiGi]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIADiGi-19May05.CAB
CAB: \Extended_ROM\DiGi_ALL.sa.CAB
RST: Reset
[DTAC]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIADTAC-19May05.CAB
CAB: \Extended_ROM\DTAC_ALL_100104.CAB
RST: Reset
[Globe]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIAGlobe-19May05.CAB
CAB: \Extended_ROM\Globe_ALL.sa.CAB
RST: Reset
[IM3]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIAIM3-19May05.CAB
CAB: \Extended_ROM\IM3_ALL_01.sa.CAB
RST: Reset
[M1]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIAM1-19May05.CAB
CAB: \Extended_ROM\M1_ALL.sa.CAB
RST: Reset
[Maxis]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIAMaxis-19May05.CAB
CAB: \Extended_ROM\Maxis_ALL.sa.CAB
RST: Reset
[New World Mobility]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIANewWorld-19May05.CAB
CAB: \Extended_ROM\New_World_ALL_122104.sa.CAB
RST: Reset
[One2Free]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIAOne2Free-19May05.CAB
CAB: \Extended_ROM\One2Free_ALL_140922.sa.CAB
RST: Reset
[Optus]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIAOptus-19May05.CAB
CAB: \Extended_ROM\Optus_ALL_140921.CAB
RST: Reset
[Orange Thailand]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIATHOrange-19May05.CAB
CAB: \Extended_ROM\TH_Orange_ALL_131922.sa.CAB
RST: Reset
[Peoples]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIAHKPeoples-19May05.CAB
CAB: \Extended_ROM\Peoples_MMS_ConnectVia_140921.sa.CAB
CAB: \Extended_ROM\HK_Peoples_ALL_140921.sa.CAB
RST: Reset
[ProXL]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIAXLMMS-19May05.CAB
CAB: \Extended_ROM\ProXL_ALL.sa.CAB
RST: Reset
[Satelindo]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIASatelindo-19May05.CAB
CAB: \Extended_ROM\Satelindo_ALL.sa.CAB
RST: Reset
[SingTel]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIASingTel-19May05.CAB
CAB: \Extended_ROM\SingTel_ALL_100104.CAB
RST: Reset
[Smart]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIASmart-19May05.CAB
CAB: \Extended_ROM\Smart_ALL_100104.CAB
RST: Reset
[SmarTone]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIASmarTone-19May05.CAB
CAB: \Extended_ROM\SmartTone_ALL.sa.CAB
RST: Reset
[StarHub]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIAPostStarHub-19May05.CAB
CAB: \Extended_ROM\StartHub_ALL.sa.CAB
RST: Reset
[StarHub Prepaid]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIAPreStarHub-19May05.CAB
CAB: \Extended_ROM\StartHub_Prepaid_ALL.sa.CAB
RST: Reset
[Sun Cellular]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIASun-19May05.CAB
CAB: \Extended_ROM\PH_Sun_ALL_131922.sa.CAB
RST: Reset
[Sunday]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIASunday-19May05.CAB
CAB: \Extended_ROM\Sunday_ALL.sa.CAB
RST: Reset
[Telkomsel]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIATelkomsel-19May05.CAB
CAB: \Extended_ROM\Telkomsel_ALL_100104.CAB
RST: Reset
[Telstra]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIATelstra-19Mayr05.CAB
CAB: \Extended_ROM\TelStra_ALL.sa.CAB
EXEC:\Extended_ROM\SetMyFavorites.exe
RST: Reset
[Vodafone Australia]
CAB: \Extended_ROM\CAB-Customization-BlueAngel-O2ASIAVodafoneAU-19May05.CAB
CAB: \Extended_ROM\Vodafone_GPRS.CAB
CAB: \Extended_ROM\Vodafone_Australia_ALL.sa.CAB
EXEC:\Extended_ROM\SetDefNetwork_Vodafone-GPRS Settings.exe
RST: Reset
Theo như giới thiệu thì cái ROM này có thể set MP3 làm ringtones. Caohung cho hỏi làm cái đó nằm trong ROM hay trong ExtRom vậy?
Hehe, caohung đen rùi :smiley:
Tui up và dùng được 2 tiếng rồi, RÂT TỐT
No sound → FIXED
No caller name → FIXED
No new SMS → FIXED
Chả mong chờ gì hơn nữa =D>
Hix, cái lỗi NO SOUND vẫn bị nhưng ít thường xuyên hơn thì phải… tớ vừa bị dính xong…
Bác Bill ơi, sao mãi vẫn chưa bắt hết lỗi vậy trời :frowning:
Hú hú hú chập chờn lắm bác TuanHa ui … em thấy hãi lắm … vẫn chưa Up lại ROM cũ kia… hic hic còn vụ set MP3 làm nhạc chuông thì em chưa test giờ test luôn đây
Tớ đang tìm mãi mà chưa thấy cái chỗ set MP3 làm ringtone ở đâu hết. Hay phải copy .mp3 vào c:\windows ???
Dù sao cái ROM này vẫn hơn ROM 02 châu Âu, bản châu Âu có thêm cái O2 Active User Interface dùng hơi bị khó chịu :smiley:
BTW, các bác cho hỏi chỗ nào có nhiều nhạc chuông MP3 nghe hay hay ấy nhỉ?
TIA
Vâng đã test ra cái MP3 làm nhạc chuông? Nếu muốn lấy MP3 làm nhạc chuông thì cần phải copy file mp3 vào windows\Rings
Còn vụ nhạc chuông mp3 thì không liên quan đến EXT_ROM đâu … em đã test đủ hết cả rồi các bác à… yên tâm không cần Ext vẫn chạy mp3 OK lắm … để em test lại cái bản 1.40 của UK xem sao
Chưa kịp UP nhưng nhìn cái EXT ROM có khối thứ có thể xoá được, toàn là các dịch vụ của các nhà cung cấp mà VN chẳng dùng đến.
Cứ tưởng nó sẽ ra WM2005 ai dè vẫn ra thêm 1 thằng 2003SE nữa. Cũng sẽ UP thử xem sao nhưng … phải backup một số thứ đã hiihhiii
Đã test về vụ lấy MP3 làm nhạc chuông… vụ này bản ROM 1.40 nào cũng chơi được hết … thôi nhanh chơi xuống ROM cũ thôi :smiley:
về sound có thể thử file này coi sao
Đã thử file Path Audio của bác và cái file Path trong bộ Ext_ROM đi kèm của bản 1.40 trong xda-developers thì thấy cả 2 cái giống nhau y hệt và thuốc vẫn vậy chẳng chữa được… em cho nó quay về bản 1.31 rồi bực mình quá đi mất :smiley:
Thế cái signature này nghĩa là sao?
Rom 1.40.00WWE
Radio 1.12.00
ExtRom (1.40.553)+caohung_cn cook
Hồi trước tui là newbie chưa dám hỏi han ai toàn nhìn signature của các bác cao thủ để học tập, thế này thì chết hết newbie rồi :stuck_out_tongue:
