VLC media player - cập nhật .
**Có đoạn tiếng anh ngắn này nên em nghĩ chả cần dịch các bác cũng biết :))
VLC (initially VideoLAN Client)** is a highly portable multi-platform multimedia player for various audio and video formats (MPEG-1, MPEG-2, MPEG-4, DivX, mp3, Ogg, OGM, MOV, wma, wmv…) as well as DVDs, VCDs, and various streaming protocols.
The VideoLAN project targets multimedia streaming of MPEG-1, MPEG-2, MPEG-4 and DivX files, DVDs, digital satellite channels, digital terrestial television channels and live videos on a high-bandwidth IPv4 or IPv6 network in unicast or multicast under many OSes.
VideoLAN also features a cross-platform multimedia player, VLC, which can be used to read the stream from the network or display video read locally on the computer under all GNU/Linux flavours, all BSD flavours, Windows, Mac OS X, BeOS, Solaris, QNX, Familiar Linux…
[size=3]Features in VLC (VideoLAN Client) :[/size][INDENT]• Rewrite of the playlist (tree structure, input preparsing …)
• Preferences improvements
• XML parsers
• Client-side SSL/TLS support
• Massive Matroska improvements
• Support for SOCKS proxy
• Support for Shoutcast Meta-data
• Support for (HE-)AAC raw-audio streams
• TiVo demuxer
• Samba (Windows shares) access module
• Dirac decoder and encoder
• PNG decoder/encoder
• Support for Apple Lossless Audio Codec
• Services discovery modules (brand new SAP module, HAL discovery, DAAP (iTunes shares), shoutcast)
• Support for 20/24 bits LPCM
• Video snapshot support (png or jpg)
• Image file video output (png)
• Mosaic (picture-in-picture system)
• Pocket PC port
• Brand new Internet Explorer ActiveX plugin[/INDENT]** * Trang Chủ](http://www.videolan.org/vlc/)**
Re: VLC media player 1.0.0 RC4.
Bản 0.9.9 vẫn là bản ổn định nhất cho đến giờ phút này.
Re: VLC media player 1.0.0 RC4.& Update
[size=4]VLC Media Player 1.0.2 Final[/size]
http://i269.photobucket.com/albums/jj44/downarchive2/member3/VLC-Media-Player.jpg
VLC (initially VideoLAN Client) is a highly portable multi-platform multimedia player for various audio and video formats (MPEG-1, MPEG-2, MPEG-4, DivX, mp3, Ogg, OGM, MOV, wma, wmv…) as well as DVDs, VCDs, and various streaming protocols.
[size=3]Features in VLC (VideoLAN Client) :[/size] [INDENT]• Rewrite of the playlist (tree structure, input preparsing …)
• XML parsers
• TiVo demuxer
• Pocket PC port
• Brand new Internet Explorer ActiveX plugin[/INDENT]Những thay đổi trong VLC Media Player 1.0.2 Final:[INDENT]
Decoders:
  • Native support for WMA Professional, without the use of the Win32 dlls
  • Fix issues in subtitles, especially SSA ones
  • Various fixes on theora and ogg
Demuxers:
  • Various fixes for EPG support in MPEG-TS demuxer
  • Fixes for potential stack overflow in .avi, .mp4 and .asf demuxers
Access:
  • Fixes for v4l2 devices
  • Fixes for dvb-c channels-scanning
Qt Interface:
  • Fix some playlist sorting issues
Mac OS X Interface:
  • Fixed a crash when updating VLC
  • Fixed a crash related to QTKit when opening video files (10.6 only)
  • Added the ability to play 2nd media in sync to the primary item (input-slave)
  • Added the “Quit after Playback” feature
Mac OS X Port:
  • The “Delete Preferences” script is now delivered as a Universal Binary
    with native code for PowerPC, Intel and Intel 64bit
  • Full 64bit runtime compatibility on both Mac OS X 10.5 and 10.6
  • no support for Goom and SDL
  • limited text rendering support
  • This port is still considered as EXPERIMENTAL despite its binary release.
Encoders:
  • MPEG2 transrate stream output removed
  • x264 default-values closer to x264.exe defaults.
  • x264 rc-behaviour fixes:
  • if user defines qp-value, CQP-mode is used
  • otherwise if user defines vb=0, CRF-mode is used
  • otherwise ABR-mode is used
  • x264 set vbv-bufsize/vbv-maxsize better if user hasn’t defined these:
  • ABR mode set vbv-max-bitrate=bitrate
  • vbv-bufsize is bitrate * seconds between keyframes (keyint/fps)
Playlist:
  • Lua scripts for Mpora and Vimeo playback
Unix builds:
  • Various fixes to enable 1.0 to build on Solaris and OpenBSD
Translations:
  • New Kazakh and Croatian translations
  • Lithunanian translation is available on Windows
  • Galician, Korean, Nepali, Vietnamese, Ukrainian, Brazilian, Arabic and French translation updates[/INDENT]** * Homepage**
  • Download
Mình dùng VLC để coi phim HD dạng .mkv, nhưng sao bị dựt quá, nhất là khi fast forward, con Media Classic Player thì hoàn toàn bó tay với HD :frowning:
Sau khi dùng BS.Player ( http://www.bsplayer.org/en/bs.player/download/ ) thì coi mượt hơn nhiều, có bản free đó các bạn dùng thử đi
Giật nhiều khi do bác cài codecs tùm lum nên nó đụng. Người khác xem thì bình thường. Dùng VLC Player thì xử lý vụ load phụ đề đi kèm rất tốt nên nhiều người thích.
Hiện nay đã có bản 1.0.2 với nhiều tính năng mới.
Link đây ạ:
 http://www.videolan.org/mirror-geo.php?file=vlc/1.0.2/win32/vlc-1.0.2-win32.exe
Dùng luôn bản Portable cho đỡ phải cài nhiều
http://portableapps.com/apps/music_video/vlc_portable
cái MCP ấy em có bao h thấy sài cho phim dạng HD mấy đâu. Giạng phim chất lựng cao như HD bác pải dùng phần mêm sem phim khác mới coi đc
Re: VLC media player 1.1.0 pre3 (02/05/2010)
[size=2]**VLC media player 1.1.0 pre3 (02/05/2010)
Một số thay đổi:
**[/size]• Decoders:
  • SubRip extra styles improvements
  • Fix potential crashes in SSA and svg decoders
    • Windows port:
  • Use of gcc 4.4.2 to compile instead of gcc 4.2. This might slightly increase performance and fix x264 issues
    • Translations:
  • Portuguese Brazilian, Lithunanian, Romanian, Ukranian, Japanese, Bengali, Walloon, Galician, Danish, Khmer, Polish, Slovenian, Vietnamese, Finnish, Russian, Slovak translation updates
  • New Malayalam, Macedoninan, Nynorsk translations
** Homepage Size: 18.6 MB
Hay xem DVD, HD rip download thì em thường dùng codec này, cũng OK lắm, có những sub VLC load không được nhưng cái này OK: http://www.mediafire.com/download.php?m1zwwo34jmt
Changes in VLC (VideoLAN Client) 1.1.2:[INDENT] * Avformat fps displaying fix
  • TS, fix an issue where some programs would get dropped (fixes DVB issues too)
    [/INDENT]Audio filters:[INDENT] * fix timestamps handling on some filters that provoqued issues when playback
    of mono streams, especially on Windows[/INDENT]**
    Windows:**[INDENT] * fix a bug in direct3d video output with old nVidia drivers that broke video
    playback with overlay (YUV->RGB)
  • fix console output encoding[/INDENT]Interface and extensions:[INDENT] * Youtube and other scripts updates
  • Misc fixes in Qt4 (especially VLM and EPG dialogs) and MacOS interface[/INDENT]** Homepage **
Download VLC media player 1.1.2 Final [.exe] ****| 18.6 MB
** Download VLC media player 1.1.2 Final [.zip]** | 32.1 MB
Changes in VLC (VideoLAN Client) 1.1.3:[INDENT]Access and demuxers:[INDENT] * fixes for FTP relatives path and FTP directory support
  • fix for podcasts parsing
  • DVD: fix an assert error and various memory leaks[/INDENT]Taglib:[INDENT] * fix NULL dereferences, as reported by FortiGuard Lab,
    CVE-2010-2937 / VideoLAN-SA-1004[/INDENT]Playlist:[INDENT] * fix a regression where the wrong entry was played
  • fix m3u playlists exports[/INDENT]Skins2:[INDENT]* fix video autoresize behaviour[/INDENT]Translations:[INDENT]* Update translations for Dutch, Sinhala, Hebrew, Estonian, Spanish and Bengali[/INDENT]Windows and Mac:[INDENT]* Update of many codecs libraries, fixing bugs and improving speed
    Mac:
  • architecture-specific installations will now be replaced by specific updates
    BSD:
  • Add AltiVec detetion for OpenBSD/powerpc[/INDENT][/INDENT]** Homepage
**** Download VLC media player 1.1.3 for Windows [exe]
**Download VLC media player 1.1.3 for Windows [zip]
