u*Blog: Viết Blog trên Palm
[size=]Chức năng chính[/size]
-Write entries on palm devices
-Handle multiple blogs
-Post entries from palm devices
-Upload files
-Configurable HTML editor
-Support MovableType functions listed below:
[size=]+Extend
+Allow comment
+Allow trackback
+Convert line break
+Trackback ping
+Keyword
+Excerpt
+Date created[/size]
[size=]Requirements[/size]
PalmOS4.x or later
Network
Color support (recomended)
Blog supporting XMLRPC APIs
Download
Đọc kỹ hướng dẫn sử dụng trước khi dùng :smiley:
Entry List
http://pam-ya.com/palmware/uBlogManual-en/img/Main.jpg
All entries in a palm device are listed in this form.
Icons in left side show entry statuses.
Palm Not posted
Arrow Posted
Pencil Edited after being Posted
When you use u*Blog for the first time. You have to tap popup trigger labeled as “NewBlog” and configure Blog Setting.
You can switch blogs by tapping same popup trigger.
When you tap New Post or existing entries, you can edit a entry.
Icon in right bottom shows network status, orange means Connected and gray means Disconnected. You can switch these status by tappin this icon.
Edit Entry
http://pam-ya.com/palmware/uBlogManual-en/img/Entry.jpg
You can edit an entry in this form.
Back Icon Save this entry in a palm device and back to a entry list form.
Trash Icon Delete this entry from a palm device.
Tool Icon Configure Detail setting
]Clip Icon Attach files to this entry.
Post Icon Post this entry to a blog.
Tag Icon Insert HTML tags and templates registered.
To register HTML tags and templates, tap Edit Tags… in the list shown when you tap Tag icon. Tag edit form will be shown.
When you edit a posted entry and post it again the old entry will be overwritten.
When you wirte in a body, later part is handled as Extend
You can write Keywords and Excerpt by choosing menu.
Attach file
http://pam-ya.com/palmware/uBlogManual-en/img/AttachedFile.jpg
When you tap Clip Icon in Edit entry form, Attach file form popups.
In this form you can attach files up to 3.
Files of any types can be attached.
Back Close Attached files form.
Preview Icon Show selected file.(Jpeg only)
Clip+ Icon Show a file list.
Trash Icon Delete a selected file form an attached file list.
http://pam-ya.com/palmware/uBlogManual-en/img/SelectFile.jpg
When you tap Clip+ Icon in Attach file form, files in a directory indicated by application setting are listed. Select a file you want and tap Select button to attach it.
You can also preview and rename files in this form.
Entry Setting
http://pam-ya.com/palmware/uBlogManual-en/img/EntrySetting.jpg
In this form detail settings are set.
Only settings which can be used selected XMLRPC Type are shown. Screenshot shows MovableType settings.
To get a category list, tap Reload… in the Category popup list.
Category tiltes must be less than 64 letters and the number of categories must be less than 32.
Trackback ping will be sent to URLs indicated by Ping URL.
When an entry is posted without date and time, current time is used as Datecreatd.
When Save as Default is tapped, all settings are save as default and they are applied to new entries.
Register HTML Tags
http://pam-ya.com/palmware/uBlogManual-en/img/TagList.jpg
In this form HTML tags and templates can be registerd.
http://pam-ya.com/palmware/uBlogManual-en/img/TagEdit.jpg
When New button or Edit button is tapped, this form will be shown.
Configure name and tag.
These macros shown below can be used in tag.
%s Selected string when Tag Icon is tapped
%f Attached file name
Blog setting
In this form you can configure blog settingsName Set blog name
Type:____________Choose XMLRPC API Type supported by your blog.
User Name:________Account name
Password:_________Account password
Host:_____________Host of your blog. See below for more detail
XML-RPC Path:______XMLRPC path of your blog. See below for more detail
BlogID Configure all settings except this and tap Find button. Blog names will be listed. Then choose one and Blog ID will be set automatically.
Set Host and XMLRPC Path as indicated below
Find out XMLRPC Path of your blog.
In MovableType, mt-xmlrpc.cgi in mt directory is the file.
For example, when XMLRPC Path is http://foo.com/cgi/mt/mt-xmlrpc.cgi
Host:From next letter of http:// to the end of domain (in this case foo.com )
XMLRPC Path:from the end of domain to the end of the path (in this case /cgi/mt/mt-xmlrpc.cgi )
More Blog Setting
In this form you can configure blog setting more in detail.Port In most case use default value.
Timeout_______________ Increase this when your blog sever is too slow.
Image Archive Path_________ Set upload directory for attached files in relative path from your blog. Take care no / is at the top of this path
Use UTC as date created____ This setting is for some Japanese blog service. Leave it as default.
Application Setting
http://pam-ya.com/palmware/uBlogManual-en/img/Setting.jpg
In this form you can set application setting.
Image Path:___ Input image archive path in externail memory. Files in the directory indicated by this setting are listed when you choose files to attach.
Line Color:____ Choose a color you like :slight_smile:
Cái cuối paste khó nhìn wá,chèn ảnh cho rồi :slight_smile:
http://i69.photobucket.com/albums/i42/x5x_pda/handheld.jpg
Bác nào xem xong làm dc thì cho em ý kiến chút
Source đây
