ftp://ftp.compaq.com/pub/softpaq/sp...000/SP30393.exe
ftp://ftp.compaq.com/pub/softpaq/sp...000/SP30393.txt
Có thêm link để đown load nữa đây
http://h18007.www1.hp.com/support/files/HandheldiPAQ/us/download/22599.html
Nhưng ở đây lại là 1.10 !!!
Chắc ROM này cũng up được cho HP6340 và 6315 đó phải ko các bac?
Bản này lúc DL thấy nói chiness Tăiwan. hãi lắm, hihi
Theo 2 cái link này đều không vào được. Mà các bác cho tôi hỏi bản ROM này có gì hay hơn cái cũ không ???
Thông tin từ trên webwite của Hp, download bản rom mới đây bạn.
** software information**
Fixes
* GSM Firmware version 541d Update:
o Fixes issue where dual-tone multi-frequency (DTMF) did not work with interactive voice response (IVR) systems.
o Fixes GSM/GPRS settings to handle connectoid name with more than 20 characters.
o Fixes issue where Inbox attachments from certain ISPs were unable to be sent over the GPRS connection.
* Wireless LAN Driver build 62:
o Fixes issue that occurred with tunneled transport layer security (TTLS) server certificate validation.
o Fixes unrecognizable characters that are displayed during login when using TTLS with MS-CHAP2.
o Fixes LEAP authentication to redisplay login prompt after tapping Cancel.
o Changes display name to "HP iPAQ Wi-Fi Wireless Adapter."
* Bluetooth build 1.0.0.3701:
o Fixes inaccurate display of headset icon when a call is in progress.
o Adds a check to determine if Bluetooth stack is initialized before accepting messages from phone.
o Adds a user interface (UI) change to enable a connected headset to automatically disconnect before attempting to connect to a different headset when the user chooses to connect to a second headset.
o Fixes check for invalid device name.
o Fixes issue where handheld could not reconnect to remote device after a page timeout.
o Fixes Object push profile update so it sends all files.
o Updates FTP connection wizard to correct service discovery issue.
o Fixes issue with call waiting for incoming call handling while dialing out.
o Fixes issue with headset connection icon so it is correctly displayed after power cycling.
o Fixes audio to make it compatible with an in-car solution.
* Fixes audio issue where the right channel for a headset was unavailable for playing audio and during calls.
* Fixes issue where the LED and network status were not properly synchronized.
* Fixes issue where the user could not send multimedia messaging (MMS) message.
Enhancements
* Provides GSM Firmware version 541d Update, which:
o Supports 64-KB SIM cards.
o Improves call handling.
o Improves reception.
* Provides Wireless LAN Driver build 62, which:
o Improves reception and roaming.
o Extends the maximum length of lightweight extensible authentication protocol (LEAP) username and password to 63 characters.
* Provides Bluetooth Software version 1.0.0.3701, which:
o Improves headset compatibility.
o Improves headset reconnection when returning into service area.
o Adds support for Siemens car adapter kit.
o Enables pairing using 16-character PIN code.
* Increases the paging-pool size from 4 MB to 6 MB.
* Activates echo cancellation for wired headset.
Theo tôi thấy cũng đáng để uprom đấy bạn, nhớ là backup lại toàn bộ chương trình đã nhé. HP uprom đơn giản lắm bạn, chúc vui.
Thế bản này là bản Chines hay là English hả bác Lampham ?
HP iPAQ h6300 Pocket PC Series ROM Update (Global Languages Support Only)
Theo tôi không phải là china đâu bạn, chỗ đó là nơi đặt site download của họ thôi. Không thấy dòng nào nói là suport china language đâu bạn ơi.
Tôi cũng đã load xong, đang tìm máy để thử đây, máy cũ đã “tiễn” rồi.
Tôi load về khó quá , được mấy mê rồi lại đứt :(( , chạy thử file down về (chắc là lỗi ) thì thấy menu toàn chữ loằng ngoằng đoán là tiếng Hoa bác ạ.
Bác có file đầy đủ thì gửi cho tôi với (nếu đường truyền bên bác tốt).
mail của tôi là : binh_nguyentan@yahoo.com.
Cám ơn nhiều.
Em đã download được bản đó rùi. Ai cần PM cho em, em sẽ gửi cho
Chú ý: bản này được hãng khuyến nghị dùng cho 6365, phiên bản của 6300 cho Asia nên cẩn thận, cần đọc kỹ hướng dẫn trước khi sử dụng
Khổ quá, tôi đã download và up rồi, chạy OK, không có chữ tiếng Tàu nào đâu
@lampham: Bạn đã nhầm với bản 1.10.09 toàn tiếng Tàu, trước bản 1.11.1 đã dưa tin ở trên tôi đã cài thành công bản 1.10.08 bản này dùng cho 6315 nhưng tôi có patch để dành cho 6365. Còn bản mới nhất này là 1.11.1 dành cho 6365 không phải theo link của bạn đâu (file 30393.exe chứ ko phải 22599), cũng nói thêm là bản 1.11.1 có thể sửa để dùng cho 6315. Dưới đây là hướng dẫn:
Đầu tiên là chạy file exe, nó sẽ tãi vào 1 thư mục, sau đó cancel setup, mở file IpaqPCSDK.dll bằng chwong trình hex editor.
Goto byte 28bd - (should be 75)change to EB 00 (changing 2 bytes)
Goto byte 295d - (should be 75)change to EB 00 (changing 2 bytes)
Goto byte 30d1 - change to EB 00 (changing 2 bytes)
Then open ALL NBF’s in hex editor and change where it says 636 to 631 at the beginning of each file.
link của anh bạn die rùi. còn ở đâu ko cho tui dl với
hm, tui tìm ra link rùi, nó là:
ftp://ftp.compaq.com/pub/softpaq/sp30501-31000/SP30393.exe
ftp://ftp.compaq.com/pub/softpaq/sp30501-31000/SP30393.txt
đang dl về để xài đây
Đang dùng link của bạn sao_lai_the để down về dùng, bản của tôi down được là SP30022, của bác là SP30393.
Tks bác nhiều.
Em đã có bản sp30022 rùi, nếu ai cần, em sẽ gửi cho.
Tôi đã load SP30393 và up lên bản này rồi, chưa biết có gì chết không I-)
Tình hình sau khi uprom như thế nào bạn, cho tôi biết với, cũng chưa có thời gian để uprom cho cục cưng nữa, bận quá.
Tôi cũng bận suốt buổi chiều nay, thấy máy vưỡn chạy và nghe gọi bình thường nhưng mà lúc cài cũng như cài xong đều báo là bản 1.11.10 ENG.
Em đã download về, bản sp30022 là bản tiếng hoa, còn bản sp30393 là bản tiếng Anh. Update vào, vẫn thấy bình thường, chẳng có gì nổi trội cả??? Chắc chưa có thời gian chọt hết
Chẳng biết được cái gì nhưng em mất toi 2 ngày vừa làm việc vừa cài lại softs. Ơn trời vừa mới xong, chưa thấy gì nổi trội cả :).
