Tớ xài thử cái này thấy rất hay—mọi người liếc thử xem thế nào
Features of PowerOn:
+Double-Press to stop unwanted power on. Press any hardware button twice within 1 second to switch on your device.
+Disable a button. You can choose to disable any hard button from ever switching on your device.
+Auto-DimTM technology. Your screen is dimmed after a period of inactivity to conserve battery while standing by for your next input.
+Accommodate lengthy task. Allow temporary disabling of Auto-Dim.
+Backlight adjustment. The backlight is disabled when your Palm is not switched on.
+Stop alarm wakeup. Stop alarms from switching on your device and wasting battery power.
Support PalmOS version 5.0 and above. Tungsten, Zire71, Treo 600, Clie, Tapwave, Garmin, etc.
More info
Gadget and Gear Reviews - PalmGear 2023
