new version has been arrived…
fixed some bugs issues
fixed chicken baseband run time error.
light size of exe.
added to no wifi method…
INSTALLOUS 4.4.2 compatible to ios 4.3.3
CAMERABUTTONS = [FONT=Trebuchet MS]take Camera pics w/ volume keys & more[/FONT]
INFINIBOARD = Vertically scroll your home screen pages!
Fully iPad, iPhone, and iPod touch compatible.
Infiniboard lets you add as many icons as you want to each page, and access them through a flick up and down.
Many settings provide full customization - and resprings don’t mess up your icons.
Created by the developer of Infinidock, Infiniboard is the ultimate way to manage your icons!
INFINIDOCKS = [FONT=Trebuchet MS]Scroll your dock with infinite icons![/FONT]
INFINIFOLDER = [FONT=Trebuchet MS]Scroll your folders and break the 12 icon barrier![/FONT]
3G UNRESTRICTOR = Now with FaceTime on 3G support. Allows you to trick applications into thinking they are on 3G even though they are on WiFi and by this remove restrictions like not being able to use VoIP apps like Skype or watch TV with slingplayer on 3G.
screenshot.
Download tại đây:
http://www.mediafire.com/?q1dm7a70ba67eda
Nếu bạn đang sử dụng Jailbroken Quick Tool phiên bản 1.5.1 hoặc 1.5.2 thì bạn chỉ cần download bản update tại đây:
