Paragon Drive Backup Professional v9.0.9 (24/09/2009)
[CENTER]http://vietgeniusco.com/svnn/playboy6006/software/system%20tools/Paragon.Drive.Backup.9.0.a.jpg
[SIZE=“5”][COLOR=“Navy”]Paragon Drive Backup Professional[/SIZE]
[/CENTER]
[COLOR=“Navy”]Drive Backup 9.0 Professional allows you to:
[ul]
[li] Backup and Restore your system without the time consuming process of applications setup and customization in the event of a system crash.[/li][li] Perform system backup without interrupting Windows using one of two Hot Processing technologies including Paragon Hot Backup™ Technology[/li][li] [COLOR=“Red”]NEW! Paragon File-Level backup™— provides full file-level backup/restore functionality including incremental backups allowing Backing up only the specific files and folders you choose rather than saving an entire drive.[/li][li] [COLOR=“Red”]NEW! Paragon File-level complement™- powerful convergent technology from Paragon Software that allows you to use advantages of two absolutely different backup types - file-level and sector-level.[/li][li] [COLOR=“Red”]NEW! Paragon Adaptive Restore™- A powerful and unique technology that allows restoring Windows Vista on completely different type of hardware or even on virtual machine. Supported types of Adaptive restore: physical-to-physical system (P2P), conversion from physical systems to virtual environments (P2V), virtual environments to physical systems (V2P) and virtual environments to virtual environments (V2V). [/li][li] [COLOR=“Red”]NEW! Dual-boot Backup Capsule- Provides Linux and DOS recovery environments for bootable Backup Capsule. Now it’s possible to choose what recovery environment to boot and provides all benefits of both Linux and DOS (safe mode) environments.[/li][li] Clone your old hard disk to deploy a new one. Eliminates having to re-install operating systems and applications.[/li][li] [COLOR=“Red”]NEW! Restore your computer with our advanced Recovery CD or from our exclusive Bootable Backup Capsule[/li][li] [COLOR=“Red”]NEW! Exclude files and folders- Ability to exclude files or folders from a backup image according to pre-defined or defined manually masks. It allows to reduce size of resulting image by excluding unnecessary files such as music, movies, etc.[/li][li] Backup to any media, including USB and Firewire devices, create bootable backup archives on CDs/DVDs and backup to network[/li][li] [COLOR=“Red”]NEW! Blu-ray disc support- Allow burning backup archives to Blu-ray discs. A single layer disc can store 25 GB, more than five times the capacity of a single layer DVD.[/li][li] Powerful Incremental and differential backup—Backs up only files that have changed[/li][li] Mount backup images to easily browse its contents and copy the required information even with standard Windows tools.[/li][li] Backup and restore dynamic volumes[/li][li] Automate your backup routine using the appropriate features and tools[/li][li] Perform basic partitioning operations. To receive maximum partitioning functionality [COLOR=“Navy”][U]buy Paragon Partition Manager 10.0 Professional[/U] today - ideal tool in combination with Paragon Drive Backup 9.0 Professional[/li][/ul]
[COLOR=“Navy”]Key Features and Benefits of Drive Backup 9.0 Professional
[ul]
[li]System Backup without interrupting Windows[/li][li]Cyclic Backup[/li][li][COLOR=“Red”]NEW! Paragon File-level backup™[/li][li][COLOR=“Red”]NEW! File-level complement™[/li][li][COLOR=“Red”]NEW! Exclude files and folders[/li][li]Data Restore & System Recovery[/li][li][COLOR=“Red”]NEW! Paragon Adaptive Restore™[/li][li]Clone Hard Drive[/li][li][COLOR=“Red”]NEW! Dual-boot Backup Capsule[/li][li][COLOR=“Red”]NEW! Complete Recovery Environment on USB Flash Drive[/li][li]Automation of Backup Routine[/li][li]MS Windows Vista support[/li][li][COLOR=“Red”]NEW! Apple Boot Camp configuration support[/li][li][COLOR=“Red”]NEW! GPT disks support[/li][li][COLOR=“Red”]NEW! Blu-ray disc support[/li][/ul]
[COLOR=“Navy”]System Requirements
Supported Operating Systems
[ul]
[li] Windows Vista (32/64-bit)[/li][li] Windows XP Professional (32/64-bit)[/li][li] Windows XP Home[/li][li] Windows 2000 Professional[/li][li] For server operating systems backup see [COLOR=“Navy”][U]Paragon Drive Backup Server Edition[/U][/li][/ul]
Supported Hard Drives and Removable Media
[ul]
[li] Parallel ATA (IDE) HDD[/li][li] Serial ATA (SATA) HDD[/li][li] External SATA (eSATA) HDD[/li][li] SCSI HDD[/li][li] All levels of SCSI, IDE and SATA RAID controllers[/li][li] CD-R/RW[/li][li] DVD-R/RW[/li][li] DVD+R/RW[/li][li] DVD+/-R (DL)[/li][li] BD-R[/li][li] BD-RE[/li][li] USB 1.x/2.0 and IEEE 1394 (FireWire) devices[/li][li] PC card storage devices[/li][/ul]
Supported File Systems
[ul]
[li] NTFS (v1.2, v3.0, v3.1)[/li][li] FAT16[/li][li] FAT32[/li][li] Linux Ext2FS[/li][li] Linux Ext3FS[/li][li] Linux Swap[/li][li] HPFS[/li][li] Apple HFS+[/li][li] Other file systems (in Sector-by-Sector mode)[/li][/ul]
System Requirements
[ul]
[li] CPU: Intel Pentium or compatible, 233MHz or higher processor[/li][li] RAM: 128 MB of RAM required (256 MB or greater recommended)[/li][li] Disk space: 100 Mb[/li][li] Internet Explorer 5.0 or higher[/li][/ul]
[COLOR=“Navy”][U][B]Homepage - Trang chủ[/B][/U]
[COLOR=“Navy”][U][B]Download - Tải về bản 32bit [103.54MB][/B][/U]
[COLOR=“Navy”][U][B]Download - Tải về bản 64bit [102.21MB][/B][/U]
[COLOR=“Navy”][U][B]Register for FREE License - Đăng ký key miễn phí[/B][/U]
