Motorola mpx 200 service codes
  • * * 8 3 7 # Version info
  • * * 3 7 2 # FQC
  • * * 3 6 4 # Engineering menu
  • * * 2 6 6 * 0 # Set as data COM port
  • * * 2 6 6 * 1 # Set as log COM port
  • * * 7 9 7 # Time to failure timer & Power down code
  • * * 2 2 6 3 * 0 # Set to default Band
  • * * 2 2 6 3 * 1 # Disable GSM Band
  • * * 2 2 6 3 * 2 # Disable DCS Band
  • * * 2 2 6 3 * 3 # Disable EGSM and DCS Band
  • * * 2 2 6 3 * 4 # Disable PCS Band
Thank you bạn nhiều nha …
