laptop gì mà kinh khung wá huhuhu...
dựa trên nền tảng của Vaio X505 thỉ phải, hãng Atom đang thiết kế 1 laptop có cấu hình khủng khiếp nhất chưa từng có :
http://atomchip.com/db4/00366/atomchip.com/_uimages/SG220-2-x-back.jpg
Processor: 6.8GHZ CPU (AtomChip� Quantum� II processor
System Compliance: Two Operating Systems with Voice Command (Microsoft� Windows� XP Professional and Linux�) / PROMT-Translator (8 languages)
Memory: 1TB Quantum-Optical non-volatile RAM (NvIOpSRAM-SODIMM 200-pin)
Storage: 2TB non-volatile Quantum RAM (NvIOpRAM-ATA IDE)
Optical Drive: DVD Super Multi / LCD Display: 12.1� WXGA (1280 x 800, 16:10) TFT Glare Type LCD display with 1.3 Mega pixel CMOS camera
Video & Graphics: Two Integrated graphic controllers [Intel�855GME internal graphics, support Intel� DVMT (Dynamic Video Memory Technology) and AtomChip� DVM (Dynamic Video Memory)]
Communication: 10/100 Base-T LAN on board, MDC Fax/Modem V.90/V.92 on Board, 802.11a/802.11b/802.11g WLAN, Intel� PRO/Wireless 2100/2200BG/2915ABG network connection, WiFi, Bluetoth, GPRS -with Bluetoth antena, CMOS camera with USB interface, Mega pixel resolution CMOS image / Pointing Device: Synaptics touchpad with 4 way scrolling button
Application Launch Key: E-mail, Internet, Capture, WLAN / LED Status Indicator: Power, Suspend/Resume, Battery Charging Status, Quantum Storage Access, Num Lock mode, Caps Lock mode, Scroll Lock mode, WLAN Lock mode
Keyboard: 3.0mm travel, inverted-T, 88keys with 2 windows key (Internet & Microsoft For Connectivity)
Interface Ports Front Side: One 4-in-1 card reader slot (support SDIO/SD/MS Pro/MS), Audio line out, Stereo Microphone-in
Interface Ports Left Side: LAN port, Modem port, SVGA�out port, One Type II PCMCIA slot (support CardBus), 1394A port (mini jack)
Interface Ports Right Side: USB 2.0 ports x 3 / Interface Port Rear Side: DC-in, Kensington Lock
Audio: Built-in two stereo speakers and Built-in Microphone / AC Adapter (Input: 100-240V AC, 50-60Hz, 1.5A. Output: 20V DC, 2.5A, 50W)
Battery: 6 cell Li-lon battery pack. Battery Charge: 3 hrs charge time to 100% capacity while system off and 4 hrs charge time while system on.
Battery Life: Approximately 8 hours for AtomChip� Quantum� II processor and 3 hours for 4 x Intel� Pentium� M processors 1.7CHz
BIOS: AMI, Support PnP, password, Bootable from USB and DVD / Power Management: ACPI 2.0 compliance / Smart Battery System Support
Security: Kensington Lock / Size: 320.0(W) x 242.0(D) x 22.0(H)mm/28.0mm (front/back)
Weight: 1.9kg(when fully equipped with AtomChip� Quantum� II processor) and 2,20kg(when fully equipped with 4 x Intel� Pentium� M processors)
Packing Accessories: Quick Guide, Support CD (Driver, Utility, Manual), AC Adapter, Power Cord, Battery Pack, BOSE Headphone Music System with noise Cancelling.
Liệu đây có phải là hiện thực, khi hãng Atom chỉ nêu 2 chữ “Coming Soon” :smiley:
http://atomchip.com/db4/00366/atomchip.com/_uimages/SystProp-x.jpg
http://atomchip.com/db4/00366/atomchip.com/_uimages/2TStorage-x.jpg
( from laptopvietnam.net)
Ặc… không phải khổng lung… à nhầm…khủng long mà là Quái zật… quả ram giống CF còn chú thích thêm 8256GB híc con PC bây giờ 8256MB đã là mơ ước … ông Atom này chắc làm quả này Microsoft chạy theo ói ra… code luôn :p.
Bộ phận làm mát… chắc = két nước giống mấy con SH :D.
Ủa nhưng cái tên Qualtum mất tích từ lâu… giờ xuất hiện lại kinh hồn hơn xưa à??
Con này đến lúc bán…giá chừng xxx000$ quá…mua con này về ko biết làm gì? hay để bắn tên lửa đạn đạo nhỉ? Quả này chắc tạo tới người ảo luôn quá…
http://atomchip.com
có báo giá đàng hòang nha : Ram là 6000$ còn HDD là 5000$ còan nguyên con super này thì chưa có giá
http://atomchip.com/db4/00366/atomchip.com/_uimages/SG220-2-x.jpg
Đúng là màn hình xấu thật sự đấy bác ạ. Chắc là xấu như vậy để giảm giá thành đây mà. Nhưng bác Alan_Hill ạ, con này mà cho độ phân giải khủng khiếp thì có lẽ em và bác phải lấy kính lúp soi mà tìm icon mất quá. Mới nhìn thấy quả RAM mà em đã ngất rồi.
À các bác xem em có nên mua quả RAM này để gắn vào máy của em không nhỉ :)) . Có lẽ gắn quả RAM này thì không cần đến ổ cứng nữa bác nhỉ, chỉ cần boot bằng USB, nạp OS vào RAM và chạy :))
À mà các bác ơi, cái ổ cứng loại này có thể gắn vào các laptop bình thường được không các bác nhỉ (tại em thấy nó dùng giao diện ATA IDE) và không biệt tốc độ truy xuất dữ liệu như thế nào nhỉ ?
Với xu hướng mới hiện nay ( deep processing, middleware ) thì mua những con quái vật như thế này chẳng để làm gì, vừa to vừa nặng vừa tốn tiền.
Bản thân mình ủng hộ nhiệt tình cho xu thế mini hóa, tiết kiệm hơn mà vẫn sành điệu
Đồng chí nào mua một con để mở cái ảnh vệ tinh chụp HN chừng 1Gb của bác Bad đi nào:D. Bad ơi, chắc con này xử ngọt cái ảnh của bác đấy…:D.
Tui nghĩ là bác cũng không nên nghĩ cách làm hại đồ chơi của mình. Nhìn cấu hình của con này thì không nên nghĩ đem đồ của nó gắn vào mấy cái máy tồi tàn của anh em mình là gì bác ạ.
Bản thân em đồng ý với anh cuhiep. Ram gì mà 1TB=1024GB ??? Sao giống sever thế? Chẳng lẽ nó chạy WinXP được (WinXP chỉ support có 4GB thì phải???
Với lại từng ấy ram thì chắc là chỗ cắm phải tua tủa, chứ làm gì có ram 256GB??? Khó tin quá???
(Nếu có gì nói sai đừng châm chọc em nha, em suy luận tý thui mừ, hì)
hihihi, cái này Bun cũng chỉ sưu tầm thôi, Bun còn ko tin nữa huống chi ai, mà nghe nói CES 2006 nó sẽ triễn lãm các con chip này tại Las Vegas, nếu có dịp Bun sẽ cố đi xem coi sao :smiley:
Em nói thế cho oai thôi bác tbatnhi ạ, chứ giá nó thế làm sao đủ tiền mà mua được ạ, có mà khâu miệng lại thì may ra … :smiley:
Em chỉ muốn biết là giao diện của nó có gì khác với giao diện của các HDD laptop thông thường hay không thôi mà.
Chỉ là sửa trong system manager và Registry thôi mà, ko tin em post hình cái máy của em chạy 20TB RAM và 40TB HDD cho các bác xem :smiley:
Hiện giờ chưa có nhà sản xuất nào sản xuất ra cái ổ cứng có dung lượng đến 1TB chứ đừng nói đến 2TB, lại còn giao diện IDE ATA nữa chứ.
Và trên lý thuyết thì các HĐH hiện giờ cho Các PC thông thường chỉ hỗ trợ RAM đến 4G là maximum.
Định dạng NTFS hỗ trợ 1 phân vùng tối đa là bao nhiêu thì em cũng ko nhớ cho lém hình như là 2 mũ bao nhiêu đó (hình như là mũ 32:D)
Nghe phét lác vật vã :smiley: Sửa mấy cái thông tin trong system info dễ ẹc, laptop thì dùng đến cỡ đó để làm gì hả trời ?? Mà đến bây giờ lại nghe thấy tên Quantum là sao nhỉ ? Maxtor mua lại quantum từ lâu lắm rồi cơ mà
Quả thật không thể tin nổi, nhưng cứ chờ cậu Bun đi Lasvegas xem thế nào đã.
ko tin được. chưa có nguồn tin chính xác nào cả cho nên tôi cho rằng chỉ là cho đùa thôi
2 bác bít thì chỉ em với, em cũng muốn chỉnh cho cái máy nhà em lên 20TB Ram và 100TB HDD, hù mấy đứa lác mắt chơi, hè hè, thxxx…
100% là đồ Photoshop
em dạo một vòng hổng thấy tăm hơi cái máy này đâu cả.
Cấu hình khủng như vầy, e rằng 10 năm hay hơn nữa mới có được
chụp lại cái hình vào photoshop, bạp bạp mấy cái ra được em laptop còn khủng hơn nữa ấy chứ, con này xi nhê gì :smiley:
http://us.gizmodo.com/gadgets/pcs/live-from-ces-atom-photo-swirl-147155.php
Máy này thấy nó xài nhiều trong phim Star Wars :D]
Nếu quả thực có cái đó trên đời thì tính cho tới thời điểm này thì cấu hình trên dành cho Laptop thì vẫn còn gọi là quá sức tưởng tượng. Ngoài quốc phòng và nghiên cứu khoa học ra tôi vẫn chưa nghĩ được là cái laptop khủng long đó được thiết kế ra để làm mục đích gì khác.
Thông tin mà bạn gì post lên là thông tin “mật” hay tin “vỉa hè” đấy. Hôm nay đọc tới topic này tôi thấy mình giống ếch ngồi đáy giếng quá, chiếc máy nhiều RAM nhất mà tôi gặp chỉ là con G5 của Apple với 4GB RAM, mà cũng chỉ bằng số lẻ của con khủng long này. Thật kinh dị. :eek:]
