tình hình là thế này mình ở bên Hà Lan và mới mua 1 laptop Dell, nhưng mà Win Vista đi kèm máy ko có Tiếng Anh nên rất bất tiện , ko biết có cách nào để khắc phục ko hay là mình phải cài Win lại và xóa phân vùng Recovery đi đây
Bro thử dùng cách này xem sao:
http://windowshelp.microsoft.com/Windows/en-us/help/2bac0e03-c331-48fc-8b7e-b66b8007512d1033.mspx
Nhà tớ k có vista để thử
Change the display language
http://windowshelp.microsoft.com/windows/supportFiles/global/gl_icon_tip.pngApplies to all editions of Windows Vista.
Which edition of Windows Vista am I using?
The display language is the language that Windows uses in wizards, dialog boxes, menus, Help and Support topics, and other items in the user interface. Some display languages are installed by [default](javascript:p(‘be27e4fc-0da6-4ffb-a100-216bcc8e28791033#gtmt_default_def’,%20’EI’)), and others require you to install additional language files. When you change the display language, it is changed for your user account and is not changed on the [Welcome screen](javascript:p(‘7415e645-ec60-4e96-8afb-8165aa37ad301033#gtmt_welcome_screen_def’,%20’EP’)). If you want to set the display language for multiple users or the Welcome screen, see Apply regional and language settings to reserved accounts.
Open Regional and Language Options by clicking the **Start** button http://windowshelp.microsoft.com/QueryWS/GetOpenContent.aspx?assetID=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&DocumentSet=en-US&RenderKey=XML, clicking **Control Panel**, clicking **Clock, Language, and Region**, and then clicking **Regional and Language Options**.
Click the **Keyboards and Languages** tab.
Under **Display language**, choose a language from the list, and then click **OK**.
NoteIf you don’t see the list of display languages, you need to install additional language files first. For more information, see Install a display language.When you change the display language, the text in menus and dialog boxes for some programs might not be in the language that you want. This happens because the program might not support [Unicode](javascript:p(‘1ec65809-f686-4887-aae2-837c1b87d40a1033#gtmt_unicode_def’,%20’EPC’)). For more information about changing the text in menus and dialog boxes for programs that do not support Unicode, see Change the system locale.
http://windowshelp.microsoft.com/windows/supportFiles/global/gl_head_STR.png**See also**
Bác thử chạy lại recovery rồi đến mục chọn ngôn ngữ các nước thì xem có chọn english ko nhé.Máy dùng cho thị trường châu Âu thường là có phần cho phép chọn ngôn ngữ(nhất là Hp).
Bác xem qua cái này xem sao : http://www.handheld.com.vn/forum/showthread.php?t=110966
