Grab_it invisible Rom Dumper (Copy rom ra SD card)
Anh buzz_lightyear thật là giỏi
Lấy rom ra không cần qua PC chỉ cần bỏ SD card vào máy thì tự đông copy rom ra SD, có công cụ này rồi thì việc copy rom từ máy này up sang máy khác sẽ dể dàng và an toàn hơn.
Còn phải cần converted tool để chuyển đổi từ *.bin ra flashable formats (chưa biết cái này)
Hi there,
there was a situation, when someone needed to grab, fast and invisible, a ROM dump off of a device at some exhibition…
Well i wrote this bad and nasty tool to do the dirty work…
all you need is a SD card (128MB) and this tool.
Setup
unpack ‘grab_it.exe’
rename it to ‘autorun.exe’
create folder ‘2577’ on your (empty) SD card
copy ‘autorun.exe’ to this folder
That’s it for the “setup”
Usage
Now every time, when you insert this SD card into PPC it will grab 64MB of ROM and save it onto root of SD card as ‘dump.bin’.
It will show you a tiny red progress bar at the very bottom of the screen.
Once done, it will beep the default sound.
Message boxes are only shown in case of any error.
IMPORTANT NOTE (thanx MDAIIIuser)
YOU MUST NOT put it back into another device!!!
YOU MUST LOCK THE SD CARD FIRST!!!
or read the SD with card reader on your desktop PC.
Otherwise, you will rewrite the dump with your own ROM!!!
This ROM dump file can be then further processed and converted to flashable formats.
it is a real spy tool :o))) i mean 007 kind of…
THANX for pieces of mamaich’s code…
Enjoy
buzz
xda-developers.com
[size=4]Download: [/size] grab_it_ARM.rar
