Giảm dung lượng các file Office bằng PowerShrink 4.0.2.0
http://i38.tinypic.com/2rgdtkw.jpg
**PowerShrink 4.0 Multilanguage + Portable | 6 MB
Compress to a minimum save the MAXIMUM!
Discover the Secret That’s Got More Than 1.120.089 MS Office-Crazy Users Worldwide Actually LOVING Compressing Time!
PowerShrink for Microsoft® Excel, Word & PowerPoint - Compress and optimize your PowerPoint presentations, Excel sheets & Word documents while keeping the original file format.
**Works with:
  • Microsoft Office: PPT, PPTX, PPTM, POTX, XLS, XLSX, XLSM, XLTX, DOC, DOCX, DOCM, DOTM, DOTX
  • Open Office: ODT, ODS, ODP, ODG, ODF
  • PowerShrink keeps the original Microsoft PowerPoint, Word and PowerPoint functionality, layout and format
  • With compression rates up to 98%, average compression rates of 62% PowerShrink allows you to reduce the total cost of ownership (TCO)
  • Many customizable options. A choice from compression rates allow you to select the perfect balance between quality and compression ratio PowerShrink can extract all images from your office files with just one click
  • Fast ROI - The low cost for PowerShrink allows the return on investment (ROI) to be achieved in very short time by:
  • Enhancing worker productivity
  • Reducing load on LAN and WAN
  • Shorter backup time and less space required on the backup media
  • Acceleration of e-mail, internet and intranet file transfers
  • No more zipping and unzipping (e.g. Winzip) is necessary for using a - PowerShrink optimized Office file
  • Users enjoys the following functionality.
  • Powerpoint compression
  • Excel compression
  • Word compression
  • Open Office compression
  • Image extraction
Những file PowerPoint mà bạn thiết kế có nhiều hiệu ứng, âm thanh,… sẽ có kích thước rất lớn, vì vậy tốc độ khi trình diễn chúng cũng sẽ chậm hẳn.
Với PowerShrink giờ đây bạn có thể thu nhỏ kích thước file xuống rất đáng kể mà vẫn bảo toàn được chất lượng file gốc cũng như cách thực hiện chúng, mặt khác sẽ tiết kiệm nhiều khoảng trống lưu trữ hơn trên đĩa.
Một số tính năng chính:
»Nén tập tin PowerPoint, Word và Excel tập tin lên đến 98%
»Trích xuất hình ảnh từ PowerPoint, Word và Excel tập tin
»Các định dạng được hỗ trợ: PPT, PPTX, PPTM, POTX, XLS, XLSX, XLSM, XLTX, DOC, DOCX, DOCM, DOTM, DOTX
»Không cần phải cài đặt bất kỳ phần mềm văn phòng để sử dụng PowerShrink
Link: http://www.4shared.com/file/Szd6sYTG/PowerShrink.html
