Fast wed- Trình duyệt cực nhanh và tiết kiệm cho iphone và ipod
Đối với những người dùng GPRS và 3G thì đây đúng là trình duyệt tuyệt vời thay thế safari. Dung lượng tải trang cực nhỏ nên tốc độ được cải thiện rất nhiều. Dùng thằng safari nhiều đúng là “hại của”
Example download sizes:
Imdb.com page
• Safari: 133k
• Fast Web: 17k
Wikipedia.org iPhone page
• Safari: 336k
• Fast Web: 20k
Đã test và thấy dùng rất tốt,tương thích với iPhone, iPod touch, and iPad. Requires iOS 2.2.1 or later . Link http://fileape.com/dl/MpTjNaHMCpIa8aXa
SWEET… It’s awesome! -Canadian Reviewer
Wow, this browser manages to go at lightning speeds, while losing nothing. -US Reviewer
This is a fantastic idea, and makes the web so much more accessible … I’m on EDGE, and my eyes went wide the first page load, then the second. It’s not a fluke…it’s FAST. -US Reviewer
When you need information fast, you need Fast Web.
Fast Web optimizes web information for the iPhone screen. Whether you are searching for Weather, Movies, or News - Fast Web gives you pages faster.
Imdb.com page
• Safari: 133k
• Fast Web: 17k
• Safari: 336k
• Fast Web: 20k
Fast web does not lay out pages like all the other browsers! Fast web uses a Google service that dramatically shrinks the pages and reformats them for a small device.
With Fast web you don’t have to have the full web layout. Fast Web just gives you the content you need at speed in a format that is easy to use.
• All text is immediately in a size that you can read.
• Text and images fit in the width of your screen (no need to keep scrolling around or zooming in and out)
• Images are automatically scaled to a size that works with the iphone screen
• Menus and sidebars are automatically ‘folded’ so that they don’t take up valuable screen space. (Simply tap on the + icon to ‘unfold’ them).
• Much smaller pages download Much Faster!
• You can still have ‘all the web’
Safari view
You can still have ‘all the web’ - just click on the ‘expand’ button and you’ll view see the page in the 100% normal layout just like Safari.
When you want to compress again, just tap the button once more.
Continual Optimization
As you browse, Fast Web keeps optimizting for you. If you want to stop optimising, just hit pause in the tool bar.
To go back to safari, just tap a button.
Fast Web will give you
• Faster smaller page loads
• Bookmarks
• Search History
• Privacy Mode
Fast Web - making your web faster !
What’s new in Version 2.0
Update to fix search bug caused by changing Google addresses
Updates UI with translucent toolbar.
Browse the web about 10 times faster.
http://www.tinhte.vn/attachment.php?attachmentid=351913&d=1300477097&thumb=1
có bạn nào có link khác không, link trên kg dow được nữa
bạn nào đã thử chương trình này xin cho mình chút review để mình tham khảo với,so với safari thì sao nhỉ
link vẫn ngon mà, đang down về test thử
Mình test rồi. Tốc độ cảm nhận nhanh hơn 1 chút thôi nhưng bị đánh đổi kết cấu trang web bị lược giản, trông như kiểu lướt wap trên nokia ngày xưa. Dùng hàng Apple mà ko nuột nà đẹp mắt thì chán quá.
Có bác nào chung cảm nhận như vậy ko ?
hic," Download ticket expired. Please try again later.", dow được chết liền
Mình cũng không down đc ??? …
Caí này là do các bạn để link lâu quá mà không kích vào download nên mới thế, sau khi kích vào dòng regular, chờ đếm 15s phải kích vào linh down ngay mới được. Link trên vẫn ngon các bác thử lại nhé. Phần mềm này rất hay vì nó tiết kiệm dung lượng tải về, giao diện thì thua safari nhưng bù lại nếu dùng 3g với GPRS mà chỉ dùng đọc tin tức thì rất nên dùng
k thể so được với safari về giao diện nhưng bù lại tiết kiệm dung lượng hơn rất nhiều, nếu chỉ dùng đọc tin tức thì rất tốt
Mình thấy Safari vẫn nhanh và mạnh hơn! Các bác nào dùng rồi cho ý kiến xem có giống mình ko?
