Noah Pro 3.0 - English dictionary
Noah Pro is an English dictionary for Palm offering 122 thousand words, support for external memory cards such as SD/MMC card or Memory Stick, memory-saving high compression of data, high-resolution screens, color, resident mode for looking up words directly from other applications and much more here:
http://www.noahpro.org/palm/noahpro/manual/gfx/np-home-def.gifNoah Pro 3.0 is an English dictionary for Palm. It offers:
definitions of 122 thousand words
lookup words directly from other programs (resident mode)
copy & paste definition to clipboard for use in other programs
support for external memory cards (SD/MMC memory cards, Memory Stick)
bookmark interesting words for future reference
3 different ways of displaying the definition
display customization - choose your own fonts and colors
efficient use of memory thanks to high compression of data
support for latest Palm OS 5 devices
support for 5-Way Navigator in Treo, Palm Tungsten
ArsLexis Thesuarus is an English thesaurus offering definitions of 48 thousand words, support for external memory cards such as SD/MMC card or Memory Stick, memory-saving high compression of data, high-resolution screens, latest Palm OS 5 devices and Treo 600/650 and Tungsten 5-Way navigator.
http://www.noahpro.org/palm/thes/manual/gfx/thes-01.gif
ArsLexis Thesaurus 1.2 is an English thesaurus for Palm OS. It offers:
support for reading database from external memory card such as SD/MMC card or Memory Stick
uses little memory thanks to high compression of data
clean and simple user interface
support for Treo and Tungsten 5-Way Navigator
Link down
Đơn giản và hiệu quả. Cám ơn bạn nhiều nhé.
Uhm, máy của mình cài nhiều từ điển wá, chẳng biết nên bỏ cái nào nữa: RoadLingua, Nexus, Noah, Columbia…
Máy của mình là Sony PEG-Sj22, chỉ có Palm OS 4.1 thì chắc không dùng được rồi. Có loại từ điển nào phù hợp hơn không nhỉ
Dòng đó có nghĩa là “dùng được cho cả Palm OS 5” chứ không phải là “chỉ dùng cho Palm OS 5”. Bạn cứ thử cài xem. Mình nghĩ là được vì từ điển thường không mấy kén chọn version của hệ điều hành.
ok, cảm ơn lotuong, mình sẽ liều thử xem sao. Hôm qua thấy có chỗ mọi người share Docstogo 8., mình hăng hái cài xong thì máy báo ko ăn vì version cao quá. Hi vong cái này ko có vấn đề gì
