Có ai biết fdisk thẻ nhớ để format lại ?
Tôi có đọc trên trang của Sandisk về trường hợp khi thẻ nhớ bị lỗi không đọc được có thể làm theo các bước ở sau. Nếu bác nào biết cách và đã từng làm xin thông báo giúp cho. Tôi có con 512MB bị lỗi, hy vọng cách này sẽ khắc phục được.
" Severe corruption on card or card has been reformatted incorrectly
Solution:
If you have a PC card adapter or a Parallel port ImageMate, you can do the following
FDISKING your SanDisk Card.
  1. Enter the Device Manager by holding the ALT key on your keyboard, and clicking twice on the My Computer icon. This takes you to System Properties wherein a tab called Device Manager resides.
  2. Click on Device Manager.
  3. Go down to Disk Drives and click twice on it.
    4.Parallel Flash or EUSB Flash or USBAT , DISK TYPE 00 or DISK TYPE 80 or 16 and double click on it.
  4. Verify in the Settings window of the drive letter assignment to assure you are looking at our card. I.E. if your card is using drive letter E: than please verify that in the Current Drive Letter Assignment is E:
  5. Click to un check the Int 13 unit box, and then hit OK.
  6. Click the OK button again to exit the System Properties window.
  7. Reboot your computer.
  8. When rebooted, go to Start then Programs and then MS DOS Prompt
  9. At the c:\windows> directory, type cd\
  10. You should now be at c:>
  11. Type: fdisk and hit enter
  12. You will see a yes or no question about disk space. Type: y, and hit enter
  13. At this point you should have an option number 5. Type 5, and hit enter
  14. Choose the option that displays the drive letter of your card. I.E. if it’s using E:, select the number that is referring to E: and hit enter.
  15. You should be back at the main menu now.
  16. Select option 3, Delete Partition or Logical DOS Drive.
  17. Select option 1, Delete Primary DOS Partition.
  18. You should be back at the main menu.
  19. Select option 1, Create DOS Partition or Logical DOS Drive.
  20. Partition created, hit escape until you get the C:> prompt
  21. Then type: format (your drive letter here)
  22. type: y, and hit enter.
  23. Type: Exit
  24. You should be in Windows again.
  25. You are finished! "
Nếu thẻ của bác bị lỗi logic còn chữa được, còn lỗi vật lý thì khó đấy, hầu hết muốn sửa được bác phải quay về DOS để sửa. Quan trọng đầu đọc của bác phải có driver để có thể nhận được qua DOS.
dùng bộ cài của Windows Xp xem sao, nó cũng hỗ trợ định dạng lại cả các Removeable đây…(dùng card reader)
trước em dùng 1 USB trancen, cũng bị báo lỗi, Window kô access vào được, format kô được luôn…
nghe mấy thằng bạn nói là Trancens có một số fần mềm hỗ trợ việc định dạng lại cho USB flash…===> đã lên down thử và xài rất tốt
tóm lại , nếu cái cách fdisk bằng bộ cài WinXp mà kô được thì thử lên trang chủ của Sandisk xem sao, biết đâu lại có cái soft tương tự như vậy
@voduy: Thấy cái này cũng hay đấy. Bác chỉ bảo cụ thể thêm được không, dùng bộ cài winXP nghĩa là như thế nào ( tôi rất hay động chạm đến thẻ nhớ )
Vì tôi cũng có một thẻ Sandisk ( chưa hỏng ) nên cũng thử tìm hiểu phần mềm theo cách của voduy và cũng thấy trên trang của Sandisk cũng có phần mềm để recuse thẻ nhớ hoặc thẻ nhớ để trong camera. Bạn muốn có bản demo thì phải đăng ký kiểu thành viên. Tôi cũng không rõ tính năng của nó hay không nhưing xem qua help thì thấy cũng được. Giá bán hơi mắc: Nếu bản single cho camera khoảng 30-40$ còn bản cho PC lên đến >200$. Không hiểu bác nào có biết về PM này hoặc nếu có chia sẻ cho anh em thì tốt.
rồi, đầu tiên bác cắm cái card reader vào cổng USB
bật máy lên, cắm đĩa cài WIN XP vào , tiến hành cài đặt như bt…
khi đến fần ĐƯỢC LỰA CHỌN PHÂN VÙNG để cài đặt WINDOW , bác sẽ thấy ổ cứng của máy PC , tiếp dưới là cái THẺ NHỚ của bác…
nếu em nhớ kô nhầm thì nó có hướng dẫn các fím để định dạng lại cái thẻ nhớ đó…
phím “D” là xoá fân vùng,
phím “C” là tạo mới ( nó sẽ cho bác lựa chọn dung lượng của thẻ nhớ bằng cách đánh dung lượng thẻ vào )
định dạng xong, bác khởi động lại máy=> vào my computer => format cái thẻ đó lại( trước chỉ là định dạng cái thẻ đó thôi-fdisk ý)
sorry vì câu cú lủng củng, em dốt văn mà :smiley:
em xin fân thành 2 mảng thế này:
1 loại là soft hỗ trợ việc recuse những tấm ảnh đã bị xoá ( hoặc bị format thẻ của máy ảnh số) => thằng này tìm trên mạng thì đầy nhưng kô tìm được “hạt đậu” :smiley:
loại còn lại là định dạng lại thẻ nhớ đó(FDISK), việc này chỉ fải làm khi WINDOW kô thể nhận diện được thẻ nữa…
cái soft để recover ảnh , anh em nào có nhu cầu ,em xin tặng, tất nhiên là cả cái " e hèm " đó :smiley:
ai cần ==> PM email cho em
