Bug Check 0x50: PAGE_FAULT_IN_N ONPAGED_AREA!!
Em xài laptop HP DV2700 t7500, vừa qua e có nâng cấp ram bằng kingston 2GB x 2. Không biết tại sao máy để từ tối đến sáng thì bị khởi động lại. Lỗi này là sao vậy các pác:
This was likely caused by the following module: syslib.sys
Bugcheck code: 0x50 (0xA424B000, 0x0, 0x95CD462A, 0x0)
Error: PAGE_FAULT_IN_NONPAGED_AREA
file path: C:\Windows\system32\drivers\syslib.sys
Em đã thử tìm trên mạng thì ra thế này:
Bug Check 0x50: PAGE_FAULT_IN_NONPAGED_AREA
The PAGE_FAULT_IN_NONPAGED_AREA bug check has a value of 0x00000050. This indicates that invalid system memory has been referenced.
Parameters
The following parameters are displayed on the blue screen.
Parameter Description
1 Memory address referenced
2 0: Read operation
1: Write operation
3 Address that referenced memory (if known)
4 Reserved
If the driver responsible for the error can be identified, its name is printed on the blue screen and stored in memory at the location (PUNICODE_STRING) KiBugCheckDriver.
Cause
Bug check 0x50 usually occurs after the installation of faulty hardware or in the event of failure of installed hardware (usually related to defective RAM, be it main memory, L2 RAM cache, or video RAM).
Another common cause is the installation of a faulty system service.
Antivirus software can also trigger this error, as can a corrupted NTFS volume.
Resolving the Problem
Resolving a faulty hardware problem: If hardware has been added to the system recently, remove it to see if the error recurs. If existing hardware has failed, remove or replace the faulty component. You should run hardware diagnostics supplied by the system manufacturer. For details on these procedures, see the owner’s manual for your computer.
Resolving a faulty system service problem: Disable the service and confirm that this resolves the error. If so, contact the manufacturer of the system service about a possible update. If the error occurs during system startup, restart your computer, and press F8 at the character-mode menu that displays the operating system choices. At the resulting Windows Advanced Options menu, choose the Last Known Good Configuration option. This option is most effective when only one driver or service is added at a time.
Resolving an antivirus software problem: Disable the program and confirm that this resolves the error. If it does, contact the manufacturer of the program about a possible update.
Resolving a corrupted NTFS volume problem: Run Chkdsk /f /r to detect and repair disk errors. You must restart the system before the disk scan begins on a system partition. If the hard disk is SCSI, check for problems between the SCSI controller and the disk.
Finally, check the System Log in Event Viewer for additional error messages that might help pinpoint the device or driver that is causing the error. Disabling memory caching of the BIOS might also resolve it.
Comments
Typically, this address is in freed memory or is simply invalid.
This cannot be protected by a try - except handler — it can only be protected by a probe
Pác nào giúp em cách khắc phục với!! Thanks các pác!
Mình nghĩ có lỗi driver của một thiết bị nào đó sử dụng syslib.sys . Bạn thử tìm thiết bị nào sử dụng driver này remove driver ra, rồi cại lại thử (nhớ update lên version mới nhất luôn). Lucky.
Pác chỉ chung chung vậy thì em cũng potay!
