Bảo vệ dữ liệu cho Treo 600 & 650 với MSafe
Mình tìm thấy phần mềm này rất hay dùng cho Treo 600 & 650 nhưng không có hạt vừng bác nào có thì cho xin với.
các chức năng :
Lock your Treo with a special SMS message
Lock your Treo when the phone is turned off (wireless mode is off), when the device is reset or SIM card removed.
Erase all your information and data on the Treo or SD card with a special SMS message
Lock your Treo when the SD card is removed
Disable SD card when Treo is locked, or leave current SD card operational but disable the insertion of a new one
Receive confirmation SMS message after Treo is locked to the number lock request is sent from and/or to another, user configurable, number.
down load tại đây http://www.MotionApps.com
