Agendus 10 Final (siêu mới) - Đang rượt đuổi Clie Organizer của Sony Clie.
Dihuta bận ăn cháo vịt, tớ post dùm…
** Agendus 10 - Tính năng mới đê, xin đừng bị chóang:**
  • Trip Wizard: new functionality allowing to create, track progress and manage trips [PRO ONLY]
  • Web Style Hyperlinks on web, email addresses and phone numbers, with tap and hold multi-menu support
  • Glance @ Agenda featuring new card style dialogs for Meetings, calls and tasks to enhance readability and navigation
  • Contact networking functionality: all new capability allowing connecting contacts to one another and name these types of relationships, new relationship types can be created too
  • Year Mode Calendar: new view calendar style showing a full year
  • All New Toolbar: icon-clustered with signal indicator on smartphones
  • Voice recording and sketching: new capability to quickly add hand drawings and recording to meetings, tasks and memos [PRO ONLY]
  • Save current view functionality: saves the currently selected filtering and show options for quick retrieval
  • New Set Time Dialog: completely redesigned, now much more usable and dpad friendly
  • New Alarm Popup Dialog: added numerous UI improvements and functionality refinements
  • Alarms on Memos: now also memos allows for alarms alarms
  • Cropping in Photo picker: images can now be cropped directly in the Agendus image picker
  • Anonymous Call Support: new functionality available on smartphones
  • Memo View Quick Search: added title bar search capability in the memo view
Major New Over The Air related features
  • Driving Directions via web browser [PRO ONLY]
  • Check For Program Updates functionality, with direct update download capability
  • Auto Update Capability allows the user to select when and how often refresh over the air data (weather, quotes, etc.) [PRO ONLY]
  • This Day In History functionality provides a set of events occurred in the past on today’s date [PRO ONLY]
  • Address Lookup & Update functionality allows for verifying, searching and updating contact information [PRO ONLY]
Improvements and Refinements
  • Today view: new task complete-in-place functionality allows for quickly checking off tasks directly in the doday view
  • Vivid Agenda: apply rules to existing items functionality, for setting color and icon on calendar, task, note and memo items at once
  • Power Search: added smart tag exclude capability (will ignore Agendus’ specific tags in items’ note)
  • Week view Block Mode and Month view Standard Mode: numerous UI improvements
  • Contact history: added preference to show last instance or every instance of repeating events
  • Enhanced address mapping: added “map address” button in alarm dialog and other dialogs whenever a contact is linked to an item [PRO ONLY]
  • Dpad navigation: implemented numerous consistency improvements through the application
  • Pictures on items: added direct camera control on Treo 650 devices
  • Introduced support for table highlight system on Treo 650, Tungesten T5, LifeDrive and latest Palm devices
  • Menus: improved labels consistency for easier navigation
  • Matrix mode icon on task items now visible in all views
  • Weather forecast icon added in month related views
  • Terminology consistency: renamed “calls” to “phone calls”
  • Improved graffiti shortcuts character mapping with shortcut letters also recognized as hotkeys and key types (on select smartphones)
  • Added “new SMS” in Menu → record [PRO ONLY]
New Preferences, and Preference related improvements
  • Preferences: improved view specific/global wallpaper management
  • Preferences: added dpad support
  • Preferences: new preference to customize in which day the week grid 5 starts
  • To-do view list mode: edit in place functionality is now a preference
  • Task preferences and show options: improved consistency with the rest of the prefs for ease of use
  • Fonts preferences: added possibility to apply the same font to all views at onces
  • Preferences: added options to select default browser and map provider
  • Preferences: possibility to activate the “new” toolbar item using the keyboard’s spacebar key
  • Preferences: task related preferences consolidation
  • Today view: added preference to turn off tomorrow’s meetings in the related slot
Còn nửa, và quá trời tính năng mới luôn,… download nhanh nhanh về xài nè…
Hình ảnh mới luôn…
http://www.iambic.com/agendus/palmos/en/images/calendar1.jpg http://www.iambic.com/agendus/palmos/en/images/contact4.gif
http://www.iambic.com/agendus/palmos/en/images/roll_scrnshot1.gif
Download: http://www.iambic.com/download/palmos/agenduspro/
Ai rảnh ghé ăn cháo vịt với **dihuta ** nhé.
Chúc vui, chú vui!!!
Tuyệt quá, nhưng sao lại demo code nhỉ?? Chắc mới quá chưa kịp mổ xe các bác nhỉ. Hôm nào có các bác up nhé
agendus được cái có thể thêm hình nền, vụ này mình khoái nhất, khong ngờ bây giờ có thêm viết tay==> ghiền
hôm nọ thấy bọn nó gửi thư kêu là chuẩn bị có bản 10,chuẩn bị upgrade,vào xem thử chưa thấy,tưởng nó loè,giờ có thật roài,thử cái!
cái này có thể nâng cấp từ bản 9.x không nhỉ, em chưa down về thử nên chưa biết
viết tay ở chỗ nào vậy bác ?
Cái kengey (nói lái!) cho Agendus vẫn làm việc tốt với anh Mười này. Bác nào cần thì PM. Mà tớ thấy Agendus10 này vẫn còn phải chào thua Clie Organizer.
7up
Anh SevenUp - “Mở lối đi riêng” - này đem Clie Organizer ra so sánh làm người ta thấy
thèm quá nha.
@all: sao mình up lên anh Mười xong, chạy ngon lành, có thấy hỏi han gì đâu hè?
Link DL ở trên die rùi. Link sửa lại nè http://support.iambic.com/forum/showthread.php?t=16877
Đây mới chỉ là bản Beta, mai mốt lên bản chính thức cũng cho upgrade Free từ bản 9.xx nếu đăng kí từ 01/08/05
Hình như bản beta này thỉnh thoảng gây reset trên Treo 650 hả bác?
Bản Beta thì đủ thứ chuyện hết bác à, bởi vậy nó mới cho mình xài thử full function. Xem ngay phần dưới khi bác click vào link, cái này cho build 596 (mới nhất cho đến giờ), tui post ở trên đó.
Bác thích nghiên kíu tất cả bug của nó (10.0 BETA) thì click vào đây http://support.iambic.com/forum/forumdisplay.php?f=61
Máy T 650 tui vẫn xài 9.06 (hồi trước dùng 9.03). Hiện giờ vẫn chưa thấy gì khác biệt với 9.03 ngoài chuyện toi thêm mấy chục kb. Tui đang chạy thử xem bản nào ổn định nhất thì ép nó vào ROM nên không chơi 10.0 Beta nên “em chã” /:slight_smile:
Đã có bản chính thức rùi đó.
Còn xử lý thì vẫn như cũ thôi. Mình đoán vậy.
Upgrade thì tối thiểu phải trả 25% → chắc cách củ khó mà hoạt đông được. Nhưng kệ, thử mới biết được. :slight_smile:
Iambic vẫn xài số đăng ký theo thuật toán dành cho Ver 9 nên chẳng có gì là ko làm được :smiley:
Nhìn Ku “Ten” này thấy mà mê :slight_smile: Có Palm chắc phải xài liền thôi :slight_smile:
Sau khi upgrade lên, cái DeviceID của em nó vẫn thế (như bản 9.0). Như vậy, theo thuật toán thì nó cũng phải “vừa” cái số cũ chứ! Đằng này em nhập vô nó lại không chịu.
Hay bác có thuật toán không generate giúp cho em phát. DeviceID: SUJCL. Đa tạ trước nhé!
Rõ ràng là anh em HHVN có rất nhiều sáng kiến để vượt “FireWall” luật :smiley:
www.postay.com =D>
Xin thông báo với các bạn là tôi cài bản thử 10.0 lên bản 9.06 thì nhất định không dùng được activation code cũ :̀(
