Đến hẹn lại lên! E-ten chính thức tung ra bản Rom Update cho E-ten M600:
Những cái mới và Fix lỗi:
-Fixed Echo problem.
To fix echo problem is required both OS 216 and audio patch, please
install MUST first OS then Audio patch (please refer to special
operation item )
-Re-modified USB driver avoid Activesync not properly connecting between
M600 and PC
-Fixed Bluetooth function will be turned off automatically problem.
-Re-adjustment backlight frequency to avoid high frequency noise.
Các bác hết chê E-ten khó nghe nữa nhé :))
Download:
Link: http://www.torq-users.net:80/listing/eten/ETEN_M600/rom/ENG-WWE/M600_WWE_0216.exe
User: eten
Pass: etendown
